Post by walleye1963 on Nov 25, 2014 20:47:23 GMT -5
Hi guys I have a 2014 qmj/157 taotao evo 150 there's a hose coming out of the trans case on the top it gos to a T with one hose going to the back of the snorkel I guess you would call it .and the outher hose going to the valve cover what I'd like to no is if I put a after market air filter on what do I do with the hose from the trans? I no I'll have to run a hose from the valve cover up the frame and put a filter on it for the valve vent but I don't no what to do with hose from the trans? Any help would be great thanks a lot guys
Post by Fox on Nov 25, 2014 22:54:48 GMT -5
Just leave it open to the atmosphere. You can even cut some of it off. Zip tie it to the rear shock maybe? Oil doesn't come gushing out of there, just fumes and moisture that condenses in there. If your engine has 2 shock mounts like most 157QMj's then you can shove the end of it into the open mount hole to keep it from flopping around back there.
Post by walleye1963 on Nov 25, 2014 23:05:16 GMT -5
cool thank you Fox I want to put a performents filter on and had no idea what it was for or what to do with it thanks again.
Post by Fox on Nov 25, 2014 23:14:31 GMT -5
You're welcome sir! I remember asking the very same question about that tube back in the day. Better to ask than to try something you aren't sure of. I found a picture:
