Post by iwannascoot on Dec 11, 2014 13:07:34 GMT -5
I got mine in the crate. There may be a switch that either was not connected or I failed to connect. I will check it out and let you know. I don't want it connected either way. Just curious. There is an unused plug in the area behind the battery box under the floor. I want to disable the brake lever switch so I can start it without holding the brake too. I find that annoying. Billy Mrx2002 just did that. He posted in his thread that he bypassed the brake switch. Maybe he would share how he did it. That would be nice if he would. It might save us from having to figure out how to do it. What do you think Mrx2002, willing to share? Billy
Post by Mrx2002 on Dec 11, 2014 15:43:31 GMT -5
Its easy your starter solenoid has two small wires for the start button. What i did was take the wire that is normally fed from the brake light switch and hooked it up to the black key switched wire that supplies 12v across the scoot. That way just as soon as your key is turned on you can start the scoot. *Edit* Also to disable the kickstand switch unplug its connector and take your volt meter while its set on ohms and test the switch some of them make contact and complete the circuit when the stand is up some break it if your switch makes contact with the stand up all you have to do is cut off the connector on the scoot side and solder the wires together. If it breaks contact simply unplug the switch.
Post by iwannascoot on Dec 12, 2014 14:51:30 GMT -5
Stupid side kick stand. Lol I had no idea that was a thing. Kick it up and off we go.blol thanx guys guess this is why I have noob next to my name That's really odd. I have a 2014 Taotao ATM50 and it has no side stand safety switch. Billy I just verified that my 2014 Taotao ATM50 does indeed NOT have a switch on the side stand. It just isn't there. It doesn't look like there is a place for one to go there. Billy
Post by 90GTVert on Dec 14, 2014 14:01:54 GMT -5
Welcome to the wonderful world of Chinese scooters. It's kinda like the old box of chocolates saying from Forest Gump.
