Post by Elektrey on Dec 16, 2014 21:43:08 GMT -5
to anyone who's worked on a TGB like this, how is this supposed to come off? I removed the 3 hex bolts and the one without any head and it still won't come up. I tried hitting it with a mallet and still nothing. Is there something else holding it on?
Post by Fox on Dec 16, 2014 22:33:35 GMT -5
It's just stuck. Wrap a rag around the handle of a socket wrench, shove it in the intake and lift upward on it.
Post by Elektrey on Dec 16, 2014 22:47:42 GMT -5
Thanks man it worked!
Post by Fox on Dec 16, 2014 22:56:17 GMT -5
Another satisfied customer!
Post by Elektrey on Dec 16, 2014 23:00:07 GMT -5
Something about a wrench lodged in the intake pipe thats different from just tugging straight up and watching the entire motor assembly come with it.
I thought I wouldn't have to take the motor case off to get it off, but it looks like I'm going to have to. Off to HF to get some jack stands.
Post by niz76 on Dec 16, 2014 23:19:38 GMT -5
The reed assembly is often a source of leaks- on a Minarelli anyway- in one thread Brent mentioned he didn't even know why he bothered to just install with the gasket as they always leak haha (tested with leak tester and soapy water). When I install the reed assy. I take great care to scuff the sealing surfaces, prep them with alchohol or some other cleaning agent, and be sure to meticulously apply a fuel-resistant sealer (I use Permatex Ultra grey MotoSeal1). Just some intel to try to help u avoid a common leak area and major pita trying to figure out why it won't run right!
Post by Fox on Dec 16, 2014 23:27:13 GMT -5
That's good advice.
I've had good results with RTV silicone after hitting the surfaces with carb cleaner and a clean rag. Of course I let the silicone set up over night before attempting to fire the engine(s)
Post by Elektrey on Dec 16, 2014 23:51:08 GMT -5
looks like I need to get a new bolt to replace the one that didn't have a head, some stands, and some gasket maker
Post by Elektrey on Dec 17, 2014 15:11:29 GMT -5
Got a tube of Permatex Ultra Grey as recommended. I saw the copper one was high heat, Is there anywhere I can't use the Ultra Grey on a scooter? It says 500 F max.
Post by niz76 on Dec 17, 2014 19:27:09 GMT -5
Got a tube of Permatex Ultra Grey as recommended. I saw the copper one was high heat, Is there anywhere I can't use the Ultra Grey on a scooter? It says 500 F max. If you got the fuel resistant stuff (there are 2 different kinds of ultra grey) then it can be used everywhere! I even use it on exhaust manifold and recently took the plunge and tried it on head gasket instead of copper spray. It works!
Post by Elektrey on Dec 17, 2014 19:59:53 GMT -5
Got a tube of Permatex Ultra Grey as recommended. I saw the copper one was high heat, Is there anywhere I can't use the Ultra Grey on a scooter? It says 500 F max. If you got the fuel resistant stuff (there are 2 different kinds of ultra grey) then it can be used everywhere! I even use it on exhaust manifold and recently took the plunge and tried it on head gasket instead of copper spray. It works! Yeah I believe I read all of them and they all said fuel resistant.
Post by Jwhood on Dec 17, 2014 20:39:23 GMT -5
yeah electric thats what i used,if u look in one of my threads,i ported the manifold open more with a dremmel too get more and better flow,polini sells a slightly bigger manifold but it shoots the carb out the rightside of scoot,they also sell a bigher reed cage but you need too do case work in order too make it fit,instructions on casework come with the bigger polini rees cage and also comes with a stuffer too direct your flow,that is the only a.m mani and rees cage for the morini,hope this info helped!!!!
Post by Elektrey on Dec 17, 2014 20:43:59 GMT -5
yeah electric thats what i used,if u look in one of my threads,i ported the manifold open more with a dremmel too get more and better flow,polini sells a slightly bigger manifold but it shoots the carb out the rightside of scoot,they also sell a bigher reed cage but you need too do case work in order too make it fit,instructions on casework come with the bigger polini rees cage and also comes with a stuffer too direct your flow,that is the only a.m mani and rees cage for the morini,hope this info helped!!!! How do you get the reed cage out? I have the engine out of the scooter but how do I get the engine mount off of the case?
Post by Jwhood on Dec 17, 2014 21:36:41 GMT -5
the pole(engine mount) has circlips on the right and left insides,you have too get circlips offand pole will slide right out!!!
Post by Elektrey on Dec 17, 2014 21:45:15 GMT -5
Ok. Guess I need to go buy some circlip pliers haha.
