Post by niz76 on Jan 27, 2015 2:26:57 GMT -5
Post by scooterpimp on Jan 27, 2015 5:42:29 GMT -5
New ones on ebay , scoot shops are 1/2 that.
Post by stevec on Jan 28, 2015 18:10:56 GMT -5
check scrappydogscooters.com you may be able to get a better price
Post by taotaodanny on Jan 28, 2015 21:03:12 GMT -5
ended up finding this guy with a junkyard full of scooters, picked the newest scooter took the full intake off and he only charged me 10
then i adjusted the valves and now it running a whole lot better
Post by taotaodanny on Jan 29, 2015 20:28:48 GMT -5
also quick question i bought a new battery this week, i was wondering if i could leave it unplugged from the scooter and stotred away, would it drain the battery?
Post by blaq on Jan 29, 2015 22:24:13 GMT -5
It would not be on same energy level as when you left it
Post by 90GTVert on Jan 30, 2015 15:04:41 GMT -5
Post by isurffl on Jan 30, 2015 21:09:48 GMT -5
your carb may have a copper plug on your air mixture screw not allowing you to adjust it. what mods (ie intake,bore kit) if any are on the scooter? sounds like your problem may be in the carb or valves, but it could also be any number of things... throttle position, leaking vaccum lines, etc. will it idle for a long time without dieing? does it idle smoothly? im no master mechanic, but i did a lot of top end work on my scooter already. i would def change the gas. premium only (90 octane or higer for the 4stroke engines. make sure all hoses and lines are properly routed.
Post by isurffl on Jan 30, 2015 21:12:00 GMT -5
disreguard then, sorry i was stuck on the first page when i replied
