Post by taotaodanny on Jan 26, 2015 0:07:40 GMT -5
whatsup guys
i recently purchased a tao tao 49 cc scooter, the scooter starts and all, but it can never get up to full throttle and shuts off after about 30 seconds of riding it, and thats with me messing with the throttle
the person that had it before said he changed out the carb and that wasn't the problem so he gave up
like i said it starts up fine but it just boggs out
anyone? thank you
Post by blaq on Jan 26, 2015 9:13:09 GMT -5
Try readjusting your mixture screw
Post by 90GTVert on Jan 26, 2015 11:30:58 GMT -5
Is the air box installed and in good condition? Sometimes people remove them or mod them looking for more power and then don't tune the carb for the additional airflow. What results is a lean condition, sometimes to the point that it hardly moves or bogs out.
Post by albongo on Jan 26, 2015 12:56:17 GMT -5
Check the valve clearances. I could make it 100 meters before my scoot bogged and died. Turned out exhaust valve was too tight.
Post by stevec on Jan 26, 2015 15:42:57 GMT -5
look for vacuum leaks, check valve clearance, make sure you are getting good fuel flow from the line.
Post by taotaodanny on Jan 26, 2015 20:59:13 GMT -5
look for vacuum leaks, check valve clearance, make sure you are getting good fuel flow from the line. *update* so i opened up the seat and bracket cause i was going to do the valve adjustment. once i opened the seat up i saw one of the lines connected to the air filter was unplugged so i plugged it back in and also noticed that there was a hole in the intake? idk if the past owner thought this would help out with acceleration but I'm going to get some duct tape and cover it up. now that i did that the scooter stays on and rides better, but it still kind of bogs out but its not too bad. I'm going to do the valve adjustment aswell also when i looked in the gas tank, the gas looked old and it was kind of brown so ill probably drain it out and put some fresh gas in it aswell
Post by taotaodanny on Jan 26, 2015 20:59:41 GMT -5
Try readjusting your mixture screw wheres that?
Post by blaq on Jan 26, 2015 21:30:27 GMT -5
Opposite of the idle screw on the side of carb
Post by stevec on Jan 26, 2015 21:36:01 GMT -5
air can get past duct tape, i would order a new intake, they are cheap on ebay. i'm glad to see it is running better for you.
Post by birdman on Jan 26, 2015 22:12:47 GMT -5
Welcome to the fun-ness and hair pulling world of scooter wrenchin.
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Jan 27, 2015 1:03:10 GMT -5
Yea but when you get them dialed in there a blast to ride and you get to grow you hair back that you have pulled out
Post by taotaodanny on Jan 27, 2015 1:22:43 GMT -5
air can get past duct tape, i would order a new intake, they are cheap on ebay. i'm glad to see it is running better for you. ok and how do i readjust it?
Post by taotaodanny on Jan 27, 2015 1:23:40 GMT -5
air can get past duct tape, i would order a new intake, they are cheap on ebay. i'm glad to see it is running better for you. alright ill look into that thanks
Post by taotaodanny on Jan 27, 2015 1:30:04 GMT -5
Opposite of the idle screw on the side of carb how do i do that? is there a thread on that?
Post by taotaodanny on Jan 27, 2015 1:36:52 GMT -5
air can get past duct tape, i would order a new intake, they are cheap on ebay. i'm glad to see it is running better for you. yea i don't know why the person before poked that hole in it, and its on the part of the intake closest to the motor so that might be messing with it. i found one for 23 shipped off a 2011 is that a good deal? or should i offer less
