larryhobman
Post by larryhobman on Feb 10, 2015 12:22:57 GMT -5
Please Help,
I ordered a 47mm kit on Ebay and I am having trouble where the chain is too tight. The head and jug are firmly seated and the tensioner is removed. When I put the chain on the cam it will not sit flat in the cradle. I have a stock jug and a 60cc jug and can get the chain on with them. The head is 60cc stock head that was on it and so is the chain. I can only come up with is the new jug is too tall. ANY IDEAS PLEASE HELP.
Post by 90GTVert on Feb 10, 2015 16:26:24 GMT -5
Sometimes along the way installing a kit the chain can be worked partially off of it's gear on the crank. Make sure it's seated properly there first and not binding anywhere.
Post by dude on Feb 10, 2015 17:36:33 GMT -5
I ran into that on a Kymco. I found the new head gasket was a thick composite type gasket. I had a steel shim gasket and that solved my problem. Look down at the crank and make sure chain is on there right.
larryhobman
Post by larryhobman on Feb 10, 2015 20:11:30 GMT -5
Thank you for the tip. I was leaning towards the jug being too tall. The OEM metal gasket does allow it to fit like it should. It still will have plenty of valve clearance I think. I cleaned up the imperfections on the intake and exhaust ports, that did enlarge them by 1mm. I am going to run a 20mm carb, should I also enlarge the intake manifold gasket to 20mm too? With that said what jet size do you suggest given I will run 5.5g rollers and what size spring should I get for the clutch? Thanks in advance Larry
