Post by Lucass2T on Feb 16, 2015 7:43:16 GMT -5
Im shopping for a new belt for the axis (minarelli short case). Right now i have a belt with stock length on a 122mm overrange pulley (stock pulleys are 115mm). Im in doubt which belt to take as an upgrade over the one i have now.
Stock belt lenght is 790mm Athena belt is 797mm (+7mm) Stage 6 OR belt is 806mm (+16mm)
Stock 115mm pulley circumference is 361,28mm 122mm OR pulley circumference is 383,27mm (+22mm)
When i look at the numbers the stage 6 belt could go with the 122mm pulley right? But then it confuses me that the stage 6 belt is designed for full-OR pulleys which are 128mm. So would the stage 6 belt be too long after all?
Post by 90GTVert on Feb 16, 2015 10:06:46 GMT -5
I'd try the Stage6 806mm. I used a Morini pulley that was 122.5mm instead of a stock pulley that was 115mm. My stock belt was a 788 and the OR belt I had was an 816. The OR belt should have been just a touch smaller, but it did work alright.
Post by Lucass2T on Feb 16, 2015 10:10:18 GMT -5
Thanks Brent! Then the S6 belt it is!
