Post by ohdanny on Mar 14, 2015 20:57:14 GMT -5
Hi, my scooter already stopped wile driving four times, on hot days.
This fourth time, it wont start any more.
The Spark plug looks a little old but good I believe, I filed electrode and re gap.
I can turn CVT pulleys by hand, I guess engine is not locked.
Please... any guidance? thank you.
Post by humanshield on Mar 14, 2015 21:16:59 GMT -5
Compression test time
Post by 90GTVert on Mar 14, 2015 21:44:19 GMT -5
Check for spark. Check compression. Make sure it's getting fuel.
Post by niz76 on Mar 14, 2015 21:46:03 GMT -5
Sounds like you may have damaged the cylinder to the point of low compression and no-start. A compression check will give a good indication of the state of the cylinder. You'll want to pull the cylinder off and have a look after any overheat "soft seize". Sounds like it's not jetted properly??
I have warped a head before overheating an engine. The head gasket wouldn't seat properly after that and had to constantly tighten the cylinder head nuts to have high enough compression to start it...
Post by ohdanny on Mar 14, 2015 22:32:06 GMT -5
OK. Thank you guy's. I'm going to check for spark now
I will then test the compression once I get a hold of the tool.
Also, small leaking somewhere from oil pump.
I am suspecting a clogged oil tank to, as oil has not gone down as much as normal (if any)
I have some gas in the air filter.
(I know, poor scooter... anyone wants to buy it?)
Post by Fox on Mar 14, 2015 22:43:26 GMT -5
Sounds like the oil pump stopped pumping. Too little oil/no oil = repeated soft seizingfollowed by engine/piston/ring damage.
Post by Jwhood on Mar 19, 2015 20:29:15 GMT -5
I'll tell you like I told several other guys be ready for headaches cause these Tgb scoots will give you one,ask me how I know,cause I have 2 and my brother has had 4 or more so I have had my fair share of migraines
Post by ohdanny on Apr 19, 2015 22:37:54 GMT -5
I'm back. I skipped the compression test. Cylinder head bolt didn't look equally tight Gaskets looked bad
Post by niz76 on Apr 19, 2015 22:47:39 GMT -5
Yep- no compression. Time for a new piston! Is the cylinder trashed too?
Post by Jwhood on Apr 19, 2015 22:56:00 GMT -5
I have a kit if interested its a 47.6 mm bbk kit I'll sell for $60 + shipping let me know,sorry to hear the bad news
Post by ohdanny on Apr 19, 2015 23:32:00 GMT -5
Yep- no compression. Time for a new piston! Is the cylinder trashed too? Cylinder is rusty an seized inside yep
Post by ohdanny on Apr 19, 2015 23:39:06 GMT -5
I have a kit if interested its a 47.6 mm bbk kit I'll sell for $60 + shipping let me know,sorry to hear the bad news Yes I am, would this fit mine? What carburetor should I get in combination with that BBK and my Leo Vince Handmade ZX exhaust, + stock variator? I was thinking of going stock for not to damage the crank.
Post by Jwhood on Apr 20, 2015 0:03:31 GMT -5
Yes I have a few Tgb scooters,I had bought for myself but switched to liquid cooled so I don't really need it now,get a dellortto clone on eBay 19mm or 21mm for like $35 (that is a carb) and a decent pipe and you should be good to go!!!
Post by ohdanny on Apr 23, 2015 20:04:40 GMT -5
Yes I have a few Tgb scooters,I had bought for myself but switched to liquid cooled so I don't really need it now,get a dellorto clone on eBay 19mm or 21mm for like $35 (that is a carb) and a decent pipe and you should be good to go!!! What brand is your BBK? it seems to cheap, is it used? tanks. I already ordered: Dellorto PHBG DS Black 21mm Racing Carburetor (Clone)
Post by Jwhood on Apr 23, 2015 20:39:05 GMT -5
Taiwanese brand just trying too help you out since I don't need it now,just opened not used brand new kit!!!!
