Post by jdl357 on Mar 27, 2015 22:30:18 GMT -5
Sometimes when starting up my scoot will rev pretty high then dies. Think it might be a vacuum leak?
Post by 90GTVert on Mar 27, 2015 22:42:51 GMT -5
Post by jdl357 on Mar 27, 2015 23:12:42 GMT -5
What about using a propane torch not lit of course, hold around carb area and listen for rpms going up. I heard this somewhere on this site.
Post by themajekalbum on Mar 27, 2015 23:20:05 GMT -5
My kymco does something similar(high revs, rarely dies but tried), if I don't ride for a few days. If I ride every day or two it starts normaly. I found that if I choke the air box for a second when it starts to high rev, it drops back to a normal idle an doesn't die. Seems like somehow(I never turn the petcock off) the float bowl is almost dry during start up then gets sucked dry without being filled.
Post by 90GTVert on Mar 28, 2015 0:02:30 GMT -5
What about using a propane torch not lit of course, hold around carb area and listen for rpms going up. I heard this somewhere on this site. Sure, if it'll stay running.
