Post by Kick start on Mar 31, 2015 13:35:14 GMT -5
I have a 08 zuma with a 19mm arreche carb and had to change the throttle cable ever sent i had change it it has been sticking right befor full throttle and cant get it to stop sticking ANY HELP would be awesome
Post by humanshield on Mar 31, 2015 14:03:07 GMT -5
A lot of new cables I see have no lubrication at all. I always put some grease at least at the last few inches.
Could also be binding in the grip.
Take it back apart and lubricate there and make sure it fits properly. Compare the ends to the old cable if it's still around.
Post by Kick start on Mar 31, 2015 14:10:43 GMT -5
A lot of new cables I see have no lubrication at all. I always put some grease at least at the last few inches. Could also be binding in the grip. Take it back apart and lubricate there and make sure it fits properly. Compare the ends to the old cable if it's still around. well it The slide in the carb thats sticks. I had to put some oil in it just for the slide to move but right befor full throttle it get stuck every time i have to take apart the carb and push the slide back done add some oil and still dose it???
Post by humanshield on Mar 31, 2015 14:13:53 GMT -5
I have a 08 zuma with a 19mm arreche carb and had to change the throttle cable ever sent i had change it it has been sticking right befor full throttle and cant get it to stop sticking ANY HELP would be awesome Welcome to the forum. Well, you said you changed the cable and ever since........ You didn't say you had the problem before you changed the cable. With your revised description, I would take a guess your needle is bent and not straight or is installed incorrectly. Take the needle out and see if the slide moves smoothly without the needle.
Post by oldgeek on Mar 31, 2015 14:16:18 GMT -5
Possibly you bent the jet needle, and it is hitting the needle jet? It is easy to do.
Sent from my SGH-T999 using proboards
Post by Kick start on Mar 31, 2015 14:21:06 GMT -5
I have a 08 zuma with a 19mm arreche carb and had to change the throttle cable ever sent i had change it it has been sticking right befor full throttle and cant get it to stop sticking ANY HELP would be awesome Well, you said you changed the cable and ever since........ You didn't say you had the problem before you changed the cable. With your revised description, I would take a guess your needle is bent and not straight. Take the needle out and see if the slide moves smoothly without the needle. thats the thing the slide will go all the way down and up but right befor full throttle it sticks. the needle go in even when the slide is all the way down
Post by humanshield on Mar 31, 2015 14:33:54 GMT -5
So is not the needle it seems. So just take the needle out and move the slide up and down with your finger so you can see what's sticking. You see any marks where it's rubbing? Disconnect the throttle cable to make sure there's no interference from it. I still ain't totally convinced it's not the cable since it started after you replaced the cable.
Post by Kick start on Mar 31, 2015 14:48:00 GMT -5
So is not the needle it seems. So just take the needle out and move the slide up and down with your finger so you can see what's sticking. You see any marks where it's rubbing? Disconnect the throttle cable to make sure there's no interference from it. I still ain't totally convinced it's not the cable since it started after you replaced the cable. it was working fin as in the carb. cable snapped got a new cable. had to take the other end of throttle cable off the carb and by that having to take the slide out after putting the new cable on the slide did not want to go in the carb at all really so I put some oil on it even with the oil its still sticking a bit at the top but not as much now the spring pushes the slide back down but that's not working enough
Post by humanshield on Mar 31, 2015 15:08:49 GMT -5
Ok, yeah yeah....that Zuma carb is like my 2 stroke Yamaha carburetors. I was forgetting for a minute. You didnt force the slide that first time did you? Take the cable back off and try it without the cable to isolate whether it's the cable or the slide. I still keep thinking the cable is sticking somewhere. I can't understand why you would have had trouble getting the slide back in after you installed the cable The slide was the same right?
Post by Kick start on Mar 31, 2015 15:21:25 GMT -5
Ok, yeah yeah....that Zuma carb is like my 2 stroke Yamaha carburetors. I was forgetting for a minute. You didnt force the slide that first time did you? Take the cable back off and try it without the cable to isolate whether it's the cable or the slide. I still keep thinking the cable is sticking somewhere. I can't understand why you would have had trouble getting the slide back in after you installed the cable The slide was the same right? really right after I took apart the carb I took the slide out and then took the cable off put the new cable on try to put the slide back in and it was a no go on that. arreche carb
