Post by simon0867 on Apr 2, 2015 10:08:56 GMT -5
I've got another question for you kind people. Can a change of spark plug change the noise of the engine?
I've noticed that the pitch of my engine seems a bit higher, it seems sharper almost more like a 2 stroke (my bike is a 4 stroke). The only thing I have done recently is swap the standard spark plug for an Iridium one as I was having a few starting issues. Had no problems since the new plug went in.
I also wondered if there might be a small hole in the exhaust but I can't see anything. The bike is running as normal but I'm just curious.
Any thoughts welcome and thanks as always.
Post by 90GTVert on Apr 2, 2015 10:33:32 GMT -5
Maybe if the old plug wasn't igniting the mixture well, and then performance should improve too. Otherwise I can't say I've noticed a spark plug changing the pitch of the engine.
Post by simon0867 on Apr 2, 2015 12:29:40 GMT -5
Thanks, starting has certainly improved with the new plug so maybe that is the case. I'll keep an eye on things over the next few days just in case.
