Post by jcataldo30 on Apr 20, 2015 16:33:49 GMT -5
Anyone know if a 93 yamaha jog cy50 has a vacuum petcock , If so where is it located I've has the whole bike apart and never could find it anyone know of anything ,
And also I tried new oil and I put super in my scooter I been running super for about a week now with no issues just better Pro-Formance and on Friday I put new oil in and yesterday I noticed that my scooter was lagging while driving , If I start out completely stopped and I slowly pull the throttle it usually gets the oil injected at around 10 mph and you can feel the pull once the oil gets injected the bike goes fast and moves quickly , now when it hits the oil injection point the bike just goes casually very slow compared to what it usually does anyone know if it could be just the oil because it's a brand I've never used before or does anyone know why I might be experiencing this thanks everyone for the help
Post by birdman on Apr 20, 2015 16:50:49 GMT -5
the fuel petcock is located behind the right side moulding. It has 2 hoses leading to the carb. and one hose leading to the fuel tank. Goodluck!
Post by jcataldo30 on Apr 20, 2015 17:36:27 GMT -5
I can't find it , is it in the open all I have is a line that goes from the gas tank to the carb ,
Post by niz76 on Apr 20, 2015 17:45:06 GMT -5
Hmmm sounds like somebody deleted it?? It should be attached to the seat bucket with two bolts...
Post by jcataldo30 on Apr 20, 2015 17:53:58 GMT -5
I've looked everywhere and it's not anywhere that I can find and the gas line is just straight right to the carb and my carb leaks constantly but I added a fuel shut off to correct the problem when it happenes but it's not a full fix like a petcock vacuum would be , and I constantly have to play with it to have the bike working correctly , anyone have a diagram on how it's suppose to be connected to the carb so if I do buy one I know how to connect it
Post by birdman on Apr 20, 2015 17:57:58 GMT -5
check the manuals section.
Post by niz76 on Apr 20, 2015 19:14:29 GMT -5
It's pretty easy- petcock will have an IN and an OUT for fuel, and a vac line which goes to the carb...
Post by tiny on Apr 20, 2015 19:43:05 GMT -5
Post by 90GTVert on Apr 21, 2015 6:32:23 GMT -5
