baotian
game over man game over
Post by baotian on Apr 24, 2015 9:46:52 GMT -5
Hi folks have replaced my stock variator on my 1e40qma 2t kept everything else the same running a mild sport pipe and 4.2 gm mallosi rollers.used to pull away fast and climb steep hills like a maniac but seems less fierce with the new naraku v.2 wich has different angles and longer ramps, does anybody have an option if I should use a tad lighter or heavier rollers cheers ni
Post by 90GTVert on Apr 24, 2015 10:23:41 GMT -5
Sounds like you should try lighter rollers or a little stiffer contra spring. Lighter weights = more RPM. Heavier weights = less RPM.
Post by vlatx on Apr 24, 2015 16:37:28 GMT -5
Can you tell us more about you setup,the naraku runs great with 3.5gr rollers on a stock torq spring. Here is a pic,the belt travel is almost to the top with 3.5gr 788 belt and a stock torq spring.
baotian
Post by baotian on Apr 26, 2015 5:38:08 GMT -5
Thats my scooter in the vid we call it a baotian falcon in the uk. Im running a 788 bando belt, didn't use the boss that came with the variator it was to short and would have stripped the crank without a lot of spacers . have 4.2gm malossi rollers in they are real nice quality and last a good amount of time,belt is nice and low in variator and about max clutch end, from what you say 3.5 gms is what I need to compensate for the ramp design of the naraku.
Post by vlatx on Apr 26, 2015 10:18:31 GMT -5
The stock contra spring is very soft,so yea you shoud try 3.5gr rollers.
Post by stuckchuck on Apr 26, 2015 17:53:08 GMT -5
you may need to shim your boss, i have 4 dif + a stock vari and all boss's are of dif lenth.I had a issue when i first modded anything on my scoot it was a new vari and belt. put the new one on and it ran worse. took it back apart put old back on and ran fine like before. long story short the drive boss was shorter on new kit and was taking off in a higher gear unknownst to me at the time.
Post by vlatx on Apr 27, 2015 8:50:51 GMT -5
the naraku comes with wery shord boss,use sthe stock one.
