benny
Post by benny on Apr 24, 2015 15:49:41 GMT -5
So i put my bbk on last night and it was fairly simple. After watching the video here i found i don't have the little screw nut thing in the oil line to make it flow more. It seems mine is vacuum feed oil? If so then it should take care of itself correct?
Post by katastroff on Apr 24, 2015 19:55:53 GMT -5
More vacuum should mean more oil. Someone slap me if im wrong.
Post by moofus02 on Apr 24, 2015 20:05:15 GMT -5
The pumps with a cable are adjustable those without a cable (like yamaha) are a fixed rate most are not adjustable although there is an aftermarket pump without a cable that has plates you change to adjust ratio
Post by joeorange on Apr 25, 2015 16:16:41 GMT -5
Just add a couple cap fulls of oil to the tank. or just tank off the oil injection and premix.
Post by vlatx on Apr 29, 2015 18:22:50 GMT -5
benny
Post by benny on Apr 29, 2015 19:52:27 GMT -5
oo that seems cool. wonder if theres somwere on ebay i can get one sent to west australia.
and for the different amounts of oil you just change the plate?.
Post by vlatx on Apr 30, 2015 14:45:23 GMT -5
Yes only the plates,I think the will send the pump for you.
