Post by Silar on Apr 26, 2015 16:57:53 GMT -5
This part in the picture is some kind of cylinder tube like thing that is over the bolt for the motor mount, but it's bigger than the bolt so it's loose and rattles around like crazy on there, especially at certain RPM's.. Can I just remove this tube, or is there supposed to me some kind of rubber insulator that goes in between the bolt and the tube? If there is, what is it called? I'd like to order one or remove this thing so I don't have to hear it buzzing and rattling...
Post by Fox on Apr 26, 2015 17:25:21 GMT -5
Put a washer on one end or one on each end if there's room. That should pinch it enough when you tighten the motor mount axle so it doesn't rattle.
Post by katastroff on Apr 26, 2015 17:34:49 GMT -5
Did you buy this scooter new? The motor mount aint suppose to be that way. That tube should be part of the bracket, and not be like that.
If the bracket is between those two mounting holes, its suppose to be in 1 piece with bushing preventing vibration.
Post by Silar on Apr 26, 2015 17:43:42 GMT -5
Did you buy this scooter new? The motor mount aint suppose to be that way. That tube should be part of the bracket, and not be like that. If the bracket is between those two mounting holes, its suppose to be in 1 piece with bushing preventing vibration. I bought it used. What is the piece called so I can get a new one? I've just removed it for now to prevent it from vibrating. I don't plan on doing any riding in the rain or on dirt roads or anything like that..
Post by katastroff on Apr 26, 2015 18:14:52 GMT -5
Its called a swing arm. You could buy a new one but... if you're cheap take the swing arm off, have the tube welded in place. Slap it all back on your scoot. If you're cheaper you can use the washer trick that Fox suggested. And if you're even cheaper then that, stuff coton in your ears.
Post by Silar on Apr 26, 2015 18:18:10 GMT -5
Its called a swing arm. You could buy a new one but... if you're cheap take the swing arm off, have the tube welded in place. Slap it all back on your scoot. If you're cheaper you can use the washer trick that Fox suggested. And if you're even cheaper then that, stuff coton in your ears. Or... If you're the cheapest of cheap.. Just remove it.. I'll probably look at getting a new swing arm later, but for now, I'm not going to worry about it if it's not causing any excess vibration or safety concerns..
Post by katastroff on Apr 26, 2015 18:24:32 GMT -5
Dont remove it. It will cause you engine to go from side to side. The tubing is there to prevent that.
Post by Silar on Apr 26, 2015 19:10:56 GMT -5
Actually, by the way it's mounted, there is no way that the engine could go side to side.
Post by katastroff on Apr 26, 2015 19:28:49 GMT -5
I guess there's only one way to find out.
Post by Fox on Apr 27, 2015 8:41:24 GMT -5
Actually, by the way it's mounted, there is no way that the engine could go side to side.[/quote] Yeah, I've seen 50cc scooters that instead of having a long axle through there with that tube in between, they have a separate bolt and nut on each side.
Post by Silar on Apr 27, 2015 8:50:13 GMT -5
That's a pretty good idea Fox! I may just have to do that!
Post by Sitticuss on Apr 28, 2015 8:18:46 GMT -5
Just when I think I have seen it all...someone always surprises me.
