Post by walleye1963 on May 9, 2015 13:29:36 GMT -5
Hi guys got taotao thunder.the kill switch hasn't worked sences I got it .wanted to do some reading before I tore into it .looked in troubleshooting and the library but I just can't seem to find anything.can someone point me I'm the right way.thanks
Post by Elektrey on May 9, 2015 14:19:46 GMT -5
If its just the kill switch I would just buy a new control thing for that handlebar, it usually isn't that much and shouldn't be hard to find since its a tao tao.
Post by walleye1963 on May 9, 2015 16:57:10 GMT -5
I'm not sure what it is all I no is it don't work I'll check tomarow thanks.
Post by Elektrey on May 9, 2015 16:58:55 GMT -5
if the kill switch doesn't work I dont know if any other parts can be responsible because I think its just connected to the CDI circuit and stops that, nothing really else to fail between there.
Post by walleye1963 on May 9, 2015 17:09:50 GMT -5
Do I really need it i ? I think it just might not be hooked up good.maybe a loose wire .
Post by Elektrey on May 9, 2015 17:10:55 GMT -5
one time I forgot to put the throttle valve back in the carb, I started up the scooter. let's just say I'm REALLY glad there was a kill switch.
Post by walleye1963 on May 9, 2015 17:15:40 GMT -5
Haha good point .i'll give it a good look.might as well see what the deal is with it .thanks
Post by scooterpimp on May 9, 2015 17:17:23 GMT -5
Suggest tracing wire (s) from kill switch , get meter or powered test light to see if switch on handlebar is actually closing , or if wire betweem it & ignition/cdi is pulled out of a connector somewhere. Seen where the thin male pins in wiring connectors have folded over instead of entering female end of connectors. I personally never use kill switch ,because if i do ill be wondering why my scoot wont start. Lol. P.s. thats how i busted my wife riding my scoots while im at work!
Post by walleye1963 on May 9, 2015 18:04:16 GMT -5
I never use it rather. Just key that's why I ask if it even maters if it hooked up or not .? If it don't need to be hooked up then why take it apart? Until I have to. But if you guys say it do's I'll check it out and fix it.
Post by walleye1963 on May 9, 2015 19:54:29 GMT -5
If I do need a switch anyone no were I can get one I can't seem to find them .not enen on taotao USA.? Just the left side.
Post by walleye1963 on May 9, 2015 19:58:16 GMT -5
Sorry .its the one like on the taotaoAtm 50cc not the 150 kind.
Post by scooterpimp on May 9, 2015 19:58:53 GMT -5
If its the 2 piece clamp on the handlebat type with mirror perch , they are a common part , ebay , pfs , scrappy etc.
Post by walleye1963 on May 9, 2015 20:05:09 GMT -5
Thanks pimp I codn't find it.I'll check it out right now .I hope its just a loose wire I hate messing with wires put got to what you got to do.did to much wireing on the boats I had .most off them were a mess.thanks.
