Clutch tune to your desired performance sans new springs
May 17, 2015 14:07:08 GMT -5
90GTVert, dan50, and 2 more like this
Post by fe53series3 on May 17, 2015 14:07:08 GMT -5
I have learned that clutch grab point is intrinsic to achieving your desired performance.
On another thread, I recently attempted to achieve this, by adding roller weight, to activate front pulley grab earlier, so causing the clutch to grab earlier.
This worked, but by adding 2g to the roller weight, I only gained 200 RPM earlier clutch grab, while the raised gearing had a much greater effect.
The experiment was a success...... but I believe perhaps a 1g increase in roller weight, and an independent improvement of clutch grab would have been more desirable.
While I have received a very kind offer of another set of springs...... my scoot performance would still be governed by specific spring strength, which would put 'performance tuning' out of my control.
There had to be a better way......... and it came to me.
Adjusting clutch grab point, without changing the springs
(Work in progress - see further below for practical modifications to the theory)
This method works for both delayed launch, and earlier launch.
For delayed launch, it may be best to get close to your desired grab point first....... experimentation will show how much we can mod the shoes without changing the springs.
Preparation:
Remove the shoes, clean them up, weigh them, and take notes.
Establish A Datum Edge:
At the flung end of the shoe (opposite the pivot end)...... find two edges that can be measured from.
Mark Off:
At the thickest metal point on the clutch shoe (at the flung end), scribe a centre line at a point where the shoe can be drilled, leaving room for increased drill sizes, and or other holes....... and centre pop each shoe at the same position.
Objective:
Delayed clutch grab: By removing metal in stages, by increasing drill sizes, or by adding more drill holes..... the decrease in weight will cause the clutch shoe to fling out later.
This can be reversed by simply adding a self tapping screw, to return to the original weight.
The advantage of this method, is that the CVT performance can be infinitely tuned, instead of being restricted to 1000 RPM steps.
Earlier clutch grab: Again, drill a hole at the flung end of the shoe, only this time add a steel nut and bolt.
This additional weight will cause the shoes to fling out earlier, perhaps to take advantage of a low RPM power increase.
Not enough?
Drill a bigger hole, and fit a larger nut and bolt.
Notes:
A tacho is a must for this mod.
With the rear wheel off the ground, put your foot on the rear wheel, and slowly increase revs.
Note the clutch grip RPM.
Start small...... drill a small hole and weigh the difference.
The closer the mod is to the flung end of the shoe..... the greater the impact.
Therefore finer adjustments can be made at the centre of the shoe.
We can add or remove weight, entirely at our will, without any concern of cost, or postage delays.
We are totally in control of our tuning.
Nice!
Preparation:
Mark Off:
Objective:
Not enough?
Notes:
Nice!
