Post by jcataldo30 on May 18, 2015 23:49:33 GMT -5
Hi I have a 2008 redstreak eco50 yy50qt-6 also on the plate it says Shanghai shenke man date 2008
Anyways , does anyone know of a manual for this bike and also does anyone know which oil I should use for the engine and also what gear oil I have to use ,
If anyone has any basic tune up info for this bike please let me know I just got this bike it was sitting for 5 years needed a new starter solonoid and battery it try's to start but doesn't turn on , oil and gas a 5 years old looking to clean tomorrow just need to know what I need to replace it , also spark plug has spark
Please let me know how I could get this running
Post by Elektrey on May 18, 2015 23:54:44 GMT -5
seems to be a subsidiary of Jonway: en.jonway.com/about.aspDon't know of any specific manuals but most likely your bike is just a generic chinese scooter that is the same as many other sold under the same name. It uses a GY6 139QMB Engine so that can help you find what oil you need. Replacing the fuel and vaccum lines and inspecting them is a good idea as they usually come with rubber which tends to crack and break over time. get some polyurethane lines. replace oil and gas like you stated. take off carb and clean it thoroughly. Check air box to make sure everything looks ok. Maybe set the valves/check them (not sure, not good with 4 strokes hehe) after doing all that see what it does and if you can narrow it down to a single problem like "carb not getting fuel" instead of "doesn't start" and you can retrace all the lines and everything.
Post by usmcdoc on May 19, 2015 6:43:20 GMT -5
As said above..it is a Jonway. Also as he said Chinese Scooters are all generic clones of each other, so no specific manual is needed for any of them. That is the beauty of these things...you can take parts off a TaoTao and put them on a Jonway..Peace Sports...etc etc..
Post by Fox on May 19, 2015 12:13:38 GMT -5
There are a few manuals at the link below for that type engine/scooter. The one that says 4 stroke and the two that say 139QMB GY6 www.49ccscoot.com/manuals/manuals.htmlGY6 is the engine family you have. 139QMB is the engine type and all the 4 stroke 50cc Chinese scooters have this engine so when searching for info or parts those two codes are invaluable. For example: If you go to Ebay to look for a carburetor and type in "GY6 50cc carb" you will get many results that target your particular engine rather than just typing "Chinese scooter carb" or "Shanghai Shenke carb" because those will also net 150cc carburetors and 2 stroke carburetors in the results.
