Post by 'O'Verse on May 22, 2015 21:27:06 GMT -5
Is the air/fuel mixture screw adjustment backwards on a real dellorto. Do I screw in the screw to give it more air? Opposite of stock carbs?
Post by Corrosion on May 23, 2015 20:57:42 GMT -5
On a phbg it is a fuel mixture screw. so out is rich.
Post by 'O'Verse on May 23, 2015 23:05:49 GMT -5
Thank you corrosion.
Post by TheAmishSasquatch on May 24, 2015 6:26:54 GMT -5
Good to know, thanks. I might be installing one of these on my Super 9 soon.
Post by 90GTVert on May 24, 2015 6:36:28 GMT -5
Easiest way to figure them out is if the mix screw is on the inlet side it controls air and if it's on the outlet side it controls fuel.
Post by fe53series3 on May 24, 2015 11:46:39 GMT -5
Is the air/fuel mixture screw adjustment backwards on a real dellorto. Do I screw in the screw to give it more air? Opposite of stock carbs? To impress your mates down the boozer...... The fuel idle screw actually meters the fuel that can be sucked up into the throat. The air idle screw (say PHBN) controls disruptive air, that limits the sucking force. Screwing out feeds more air to the fuel port, so limiting fuel delivery. Therefore, by controlling the air, the fuel is metered. Of course, it is enough to simply know that 'out' is weaker, and 'in' is richer......... but knowing why is always good for morale It's a shame that the info is unlikely to impress the ladies........ not the greatest 'chat up' line
