Post by andrew2841 on May 24, 2015 17:39:56 GMT -5
Hi, i need help removeing my grips on my taotao 150 gy6 to install better looking ones. Thanks. A video would b great
Post by katastroff on May 24, 2015 18:21:25 GMT -5
You can spray WD-40 into them, Blow air into them, cut them off...
Blow torch and jack hammer are not recommanded.
Post by andrew2841 on May 24, 2015 18:26:11 GMT -5
Are you serious?? I thought there was a better way of removing them.
Post by katastroff on May 24, 2015 18:31:41 GMT -5
Easiest way it to simply cut them off with a drywall knife if they are not loose enough to be pulled off by hand.
Post by katastroff on May 24, 2015 18:32:53 GMT -5
By "grips" you mean them rubbers on the handle bar right?
Post by Fox on May 24, 2015 19:44:28 GMT -5
I concur... Cut them off with a sharp utility knife but be careful on the throttle side. Put just enough pressure to gut through the grip. There is a plastic sleeve on that side. you don't wanna split it open. The new grips should slide on easier with some soapy water. (dish soap and water works good) The soapy water will dry eventually and the grip will be good and stuck to the bar ends.
If you use a lubricant or petroleum product like WD40 to get the grips to slide on easy thent they will also slide off easy and that's not good.
Post by Elektrey on May 24, 2015 19:49:25 GMT -5
Take a can of wd40 with that little red tube and slide the tube up inside the end of the grip and just blast away. start working the grip rotationally around the handlebar while pulling and it should start to give. you can always take a knife and slice through it also.
I put my grips back on without glue of any kind and possibly even using wd40 can't remember, but they fit really well.
Post by kkzxxx on May 25, 2015 6:19:09 GMT -5
well, ive used a heat gun and got them off without damage
Post by katastroff on May 25, 2015 7:57:48 GMT -5
In your original post, you wanted a video. Found you one:
Post by scooterpimp on May 25, 2015 8:58:25 GMT -5
Who would want to save / reuse those china plastic grips anyway? Hack em off! Lazer them off!
