Post by Deleted on May 27, 2015 8:17:54 GMT -5
My scooter have old style front suspension, but the front schock it's in cheap plastic and too smooth! It's always knock on every bump.... And the rear suspension is 2 smalls shock and they are too stiff!!! Last week i try a scooter with gas suspension, wow it was very soft. Is it possible to change this cheap suspensions on my scooter? And if i check on the web, how i know is going to fit on my scooter??? Check the length!? Thank's!
Post by Elektrey on May 27, 2015 11:36:13 GMT -5
yeah your going to want to take the springs off the frame in the back and measure the unstretched length and you can usually find them on ebay for around $50 a spring or like $80 a set make sure the mounting points match up.
that should work I think all scooter springs are the same size bolts and stuff but it may not, post pictures of the springs in the back to make sure.
Post by 90GTVert on May 27, 2015 12:42:50 GMT -5
Rear shocks should be easy enough. As said, measure eye to eye (on center, uncompressed) and then find shocks of the same length and just look at the pics to verify the same mounting style as your scoot. May be able to do the same with that style of front. Can't say I've ever tried.
