Post by walleye1963 on Jun 1, 2015 10:55:20 GMT -5
NGK CR7HS.is this the right plug for a taotao thunder 50? Thanks guys
Post by 90GTVert on Jun 1, 2015 11:10:52 GMT -5
Yes.
Post by walleye1963 on Jun 1, 2015 12:03:07 GMT -5
Thanks brent. Just wanted to make sure because im putting that bbk on if the weather let's me. That's the same plug I put in when I got it new.just wanted to make sure I used the right one got it off your vid.thanks again.
Post by Elektrey on Jun 1, 2015 14:07:04 GMT -5
you could move up to a CR8HS for a cooler plug, might help with temps since you have a BBK.
Post by walleye1963 on Jun 1, 2015 18:41:26 GMT -5
you could move up to a CR8HS for a cooler plug, might help with temps since you have a BBK. I haven't put it on yet been reading Brents how to put on bbk for the last few weeks want to make sure I no what I'm doing and do it right.my first.waiting on jet kit .won't be here till friday.+ waiting n variator fan f....d it up when I put perf variator on pinched belt .you no what I mean.so I should move up to the plug CR8HS with the bbk? Thanks guys don't no what I'd do without you. Walk and I don't have the body for walking.
Post by Elektrey on Jun 1, 2015 19:34:37 GMT -5
Yeah It's not a bad idea to move up a heat range.
too hot a plug and well you seize too cold a plug and the spark plug gets fouled.
BBK should produce more heat so a CR8HS seems like a good bet to make. I switched mine from a 7 to an 8 when I did my BBK
Post by walleye1963 on Jun 1, 2015 19:47:07 GMT -5
Man.just went and got the CH7hs.in this town you got to order before hand.I'll call to order one.I can count the scoots in this town on one hand. Witch makes me sick.cagers.just don't get it.but they will.when there paying $5 for gas.thanks guys.
Post by scooterpimp on Jun 1, 2015 19:52:47 GMT -5
Cr7hsa
Post by usmcdoc on Jun 2, 2015 7:01:39 GMT -5
you could move up to a CR8HS for a cooler plug, might help with temps since you have a BBK. CR8HS is what I settled on with my BBK since I used the stock head my compression was a bit higher and the plug seemed to run way hot. I suppose just try both and see what works best for you...since we all live at different elevation and in different environments.
Post by walleye1963 on Jun 3, 2015 17:09:35 GMT -5
OK so I called all the big parts places in town today looking for a NGK CR8HS plug .they told me they don't have them.I ask if they could order me one.they say no.? So I was thinking.there's a small place that fixs/sells lonemorers. Sorry about the spelling so I go there they don't have it in stock but said they could order it and it would be here in 2 days.cool I paved for it.they tell me they don't make that plug anymore? The one they have now is a CR8HSA.she looked it up and that's what it calls for .so is this plug the right one for a bbk?thanks guys.sorry about this bing so long.
Post by Elektrey on Jun 3, 2015 17:18:26 GMT -5
I found the same thing. Went to O'Reilly auto and they ordered me one, picked it up next day in the morning highly recommend!
as far as the CR8HSA goes, on the code symbols thing for NGK it states "A" for firing end side as: "A Special Design"
Does it look any different than what you have? Sounds like maybe you got a mower plug or something...
BR8HS should look identical to BR7HS
Post by ryan_ott on Jun 3, 2015 17:59:58 GMT -5
Most Honda bike shops should have the CR plugs in stock, small TRX and ATC series bikes use them.
Post by walleye1963 on Jun 3, 2015 18:40:15 GMT -5
It come in Friday so I don't no what it looks like yet.they looked it up in the book and said it was the one.honda moved on a long time ago.I'm running the CR7HS right now.doc and elektrey said to go up a heat range hier.witch is CR8HS.
Post by scooterpimp on Jun 3, 2015 20:19:40 GMT -5
Alot of auto parts stores have no clue if asking for a cr7hs etc. But if you find the ngk stock # thats on the box they usually have it on the shelf. (Unless you actually have someone with knowledge working the counter ) i even give the ngk stock # to my local pep boys/advanced auto & they still ask what kind of car its for.
Post by Elektrey on Jun 3, 2015 20:29:13 GMT -5
All the big name auto parts stores don't carry the "8" heat range plugs because its too specialty for application, i.e. "racing engines" lol
at least thats what I was told
