Post by taotao15 on Jun 9, 2015 9:38:25 GMT -5
HI guys how are doing to day ? i am getting a hard time with my moped TaoTao ATM50-A1 50cc , it is brand new i bought 2 months ago and has 450 milles, but 4 days ago when coming home i stooped at store to buy some stuff , when i back to the moped i try to run it and ..... no things . hopefully my friend help me to get it home. i started a series of tests: 1. fuel line check : to bypass the fuel valve issues i connect thew carburetor directly to the fuel filter. 2. clean the vacuum line: actually it was clean. 3. change the spark plug : before putting a new spark plug i crank the scooter and i put my fringe in the spark plug hole i feel pressure but i don' t really feel a fuel (i am not sure how much fuel should i get in this step) but since it start -sometimes- i conclude that it got gas .............euuuh rigth ? 4. clean the carburetor : with carburetor cleaner i can't get to carburetor jets it's sealed carburetor grrrrrrrrrrrrrr 5. clean the air filter. 6. change engine and gear oil. 7. check the resistance on the the automatic choke : hard to read but it seem something like 10 ...12... 8. Valve adjustment : i am in this step but before i process i want to be sure i am not missing some thing. NOTICE : i get lucky sometime and the engine start running, but i have to give him lot of gas to continue runing. if i give it less gas it stop immediately, and i feel like it lost a power . hope to hear from you soon guys
Post by 90GTVert on Jun 9, 2015 14:20:06 GMT -5
Post by taotao15 on Jun 9, 2015 14:33:45 GMT -5
thank you @90gtvert
Post by humanshield on Jun 9, 2015 16:09:43 GMT -5
Since it happened "suddenly" and didnt show symptoms before (or at least you didnt say so), it could be an air leak.
Check ALL the vacuum hoses and tighten up the intake nuts on top of the manifold.
Also be aware that it is always possible to get bad gasoline. They have filters on them and all but it isn't unheard of.
After that I would def check the valve adjustments.
Post by niz76 on Jun 9, 2015 16:41:23 GMT -5
Had a similar issue just last night. Would only start and run at at least half throttle. Ended up being a clogged idle jet...
Post by Fox on Jun 10, 2015 9:46:36 GMT -5
Odds are it's not what happened to you but one thing that hardly ever gets mentioned is that mixture screws can vibrate loose and fall out.
Post by taotao15 on Jun 10, 2015 11:05:28 GMT -5
I find the issue !!! cracked air intake manifold but it was so hard to discover since it is hid read thisDo you know better replacement intake ? this seem very bad quality
Post by walleye1963 on Jun 10, 2015 11:52:56 GMT -5
I think scrappy dog has a all crome one.
Post by scooterpimp on Jun 10, 2015 18:01:34 GMT -5
I think hoca makes one also , but its like 35 clams
Post by 90GTVert on Jun 11, 2015 8:15:44 GMT -5
Post by Fox on Jun 11, 2015 11:48:33 GMT -5
