wayho
Scoot Newb
Post by wayho on Jun 9, 2015 18:04:35 GMT -5
My son purchased a used ATM50-A1. After dropping it, it no longer would start.
Removed the plastic to find loose switch wires. They were just hanging where they had previously just been twisted together.
Now here's my problem:
The key switch has 5 wires: Green, Green, Black, Red, & Black/White
There are only 4 loose wires from the wiring harness: Green, Red, Black, and Black/Blue.
Which ones connect where?
Any help would be GREATLY appreciated!!!
Post by scooterpimp on Jun 9, 2015 19:46:27 GMT -5
Green wires are usually for grounding out the cdi (engine kill) usually one goes to cdi other to chassis , so when key is turned off it grounds out/off. Red to red , black to black , blackblue to blackwhite. Should let lights turn on & allow to start , if a meter is handy ? Check for continuity between the 2 greens with switch off. (usually 1 green to chassis other to green wire from cdi) also make sure inline fuse didnt blow when wires pulled apart.
wayho
Scoot Newb
Post by wayho on Jun 10, 2015 18:32:11 GMT -5
Scooterpimp! You are awesome!! You just made my son's day! Thank you so much! Worked like a charm!
Post by scooterpimp on Jun 10, 2015 20:13:07 GMT -5
Very glad to be of help
