Post by Majestic on Jun 10, 2015 15:13:00 GMT -5
The petcock on my 2007 Vento Triton Li 2T is occasionally sticking closed and I want to replace it. I was wondering if anyone knows if the petcock on my model is the M16 x 1 or M14 x 1?
Thanks !
Post by scooterpimp on Jun 10, 2015 18:07:10 GMT -5
The safest route would to measure it , that way there is no guessing
Post by thatcrazyguy on Jun 10, 2015 18:51:05 GMT -5
The safest route would to measure it , that way there is no guessing [br I back this up. Also, switch to a manual petcock. I have replace 3 vacuum peacocks in the last 6 months. Cheap Chinese b.s. I am still running on a vacuum petcock but when this one goes I am for sure switching to manual!!! (Elektrey with the enfluence!!!!)
Post by 90GTVert on Jun 11, 2015 7:52:53 GMT -5
Post by ewasleske on Jun 11, 2015 9:30:32 GMT -5
Mine were 16 by 1.5. Best to remove it and measure. I have learned the hard way to know what you need and what you're getting before ordering!
Post by 90GTVert on Jun 11, 2015 9:48:14 GMT -5
Very true. A little measuring sometimes saves a lot of frustration and waiting on correct parts to replace the wrong ones.
Post by Majestic on Jun 11, 2015 9:50:12 GMT -5
Thanks for the info!
At this point I'll measure it to be sure. I was hoping to avoid draining the tank down for the measuring, but I guess is has to be done.
As for the manual petcock, I'll give a vacuum petcock another try. Everything on the scoot is stock and it runs very well so I want to avoid modifications if need be. If the new petcock fails rather quickly then a manual for sure.
Thanks again everyone !
Post by Majestic on Jun 30, 2015 10:04:18 GMT -5
You are correct. Mine was the 14mm x 1 as well. I installed a new one and she's back up and running. Will have to see how long it lasts. Has anyone ever purchased and tried the manual petcocks? In searching the Internet I see there are a couple available in the 14mm size. That would eliminate the need to piece something together.
