Post by renagade281 on Jun 27, 2015 11:46:31 GMT -5
Everything electrical works on my scooter except my front right turn signal (the bulb is good). Just trying to see if maybe one of these are why. I can't see where they would plug in to because there's nothing for them to plug to. I wouldn't be so lucky as to find out that either of these are why my scooter is running so crappy that I have to walk it up hills?? Probably not :-(
Post by Clank on Jun 27, 2015 18:06:07 GMT -5
First one is possibly a plate light, the second is for a kickstand safety switch which isn't installed on most TaoTaos
Post by renagade281 on Jun 27, 2015 18:24:32 GMT -5
Thanks
Post by scooterpimp on Jun 27, 2015 22:29:32 GMT -5
Plate light is built into tail/brake light. Should have clear spot on lense bottom., check connectors in bulb holder socket.
Post by katastroff on Jun 28, 2015 6:32:07 GMT -5
First one is possibly a plate light, the second is for a kickstand safety switch which isn't installed on most TaoTaos You mean this safety switch?
Post by Fox on Jun 28, 2015 11:04:34 GMT -5
Many scooters have the same two open plugs. Nothing to worry about and for sure not causing the engine to run funny.
Post by Availien on Jun 28, 2015 22:31:12 GMT -5
First one is possibly a plate light, the second is for a kickstand safety switch which isn't installed on most TaoTaos You mean this safety switch? Why?!
Post by Clank on Jun 28, 2015 23:01:51 GMT -5
First one is possibly a plate light, the second is for a kickstand safety switch which isn't installed on most TaoTaos You mean this safety switch? Baahahahaha Baahahahaha Baahahahaha. That's too funny...
Post by 90GTVert on Jun 29, 2015 7:50:47 GMT -5
If only one signal didn't work I'd check for both power and ground at the connector when the signal is turned on for that side. Should see a steady ground and flashing/intermittent power. If you don't get those you need to trace the wiring and find out why. I doubt the cause will be the connectors shown. As Fox said, random unconnected plugs aren't uncommon on Chinese scoots.
Post by Deleted on Jul 2, 2015 16:26:10 GMT -5
in your top pic: thats a brake light wire, there is a LED strip brake light on some scooters that have that 'spoiler' looking cover over the pillion handle: in your bottom pic: kick stand kill switch, that yours doenst have (this makes for a great valet switch)
