Post by renagade281 on Jun 29, 2015 0:00:12 GMT -5
Are there any other things I would have to do if I got an aftermarket exhaust?
Post by Elektrey on Jun 29, 2015 0:00:33 GMT -5
rejet possibly
Post by renagade281 on Jun 29, 2015 0:09:03 GMT -5
I see some exhauSts that look like a trombone sort of. Lol that's the only way I can describe it. Like the exhaustexhaust pipe loops back around
Post by Availien on Jun 29, 2015 0:14:48 GMT -5
I'm no expert in this area, but from what little I think I know, the stock mufflers provide a certain amount of "back pressure" required to keep the engine running correctly. That same back pressure can inhibit the flow of expanding gases when installing a BBK, reducing the efficiency of the build. That being said, an open-style air intake (a pod like mine or a UNI) and a bigger carburetor paired with a free flowing exhaust, all help the engine run more efficiently and "breathe" better (especially with BBK's). Like Elektrey said, possibly different jet. Even then, it may not run like it COULD with a bigger carburetor or open style air filter. I have no clue what I'm talking about though. I'm still learning things myself. Best teacher is experience. If you decide to get it, install it, see how it works, post results and get some help if it doesn't run right.
Post by Availien on Jun 29, 2015 0:15:23 GMT -5
I see some exhauSts that look like a trombone sort of. Lol that's the only way I can describe it. Like the exhaustexhaust pipe loops back around That's a 2- stroke exhaust.
Post by Availien on Jun 29, 2015 0:17:35 GMT -5
This is a 2 stroke exhaust pipe
Post by Availien on Jun 29, 2015 0:22:30 GMT -5
Walter Kaaden discovered how to use these things to boost power in 2-strokes in the 50's
Post by 90GTVert on Jun 29, 2015 7:46:06 GMT -5
Naraku, and maybe others, make pipes that mimic a two-stroke expansion chamber sort of like what Availien posted. They have quite a small header from the pics I've seen. I know that at least one member bought one and reported disappointment. IIRC he said it performed worse with that pipe.
