Post by renagade281 on Jul 7, 2015 13:21:27 GMT -5
Last night my headlight blew. High and low beam so I had to hold a flashlight the whole way home
Post by thatcrazyguy on Jul 7, 2015 13:30:23 GMT -5
When my headlight blew I pulled the light socket out and stuck a 6inch flashlight in there
Post by spaz12 on Jul 7, 2015 14:00:37 GMT -5
Last night my headlight blew. High and low beam so I had to hold a flashlight the whole way home I used the light from my phone to drive all the way across town. Damn near got killed twice.
Post by 90GTVert on Jul 7, 2015 14:15:05 GMT -5
Check your tail light to see if it's still alright and the voltage when revved. If it's getting much above 15V you may have a regulator issue.
Post by renagade281 on Jul 8, 2015 16:54:02 GMT -5
Check your tail light to see if it's still alright and the voltage when revved. If it's getting much above 15V you may have a regulator issue. I don't know if this effects the light but I bypassed the fuse by the battery because I accidentally let the fuse wire touch the ground so it fried that short wire from the fuse to the battery so I just spliced them together and now I have no fuse. This happened weeks ago. The headlight still worked After that
Post by 90GTVert on Jul 9, 2015 8:58:59 GMT -5
That's a bad idea. A cheap little fuse will protect more expensive components and reduce your risk of melted wires or even a fire someday.
Post by renagade281 on Jul 9, 2015 13:06:04 GMT -5
That's a bad idea. A cheap little fuse will protect more expensive components and reduce your risk of melted wires or even a fire someday. ok could i use a wire and fuse from say a car stereo ?
Post by 90GTVert on Jul 9, 2015 13:11:10 GMT -5
Post by ryan_ott on Jul 9, 2015 19:05:38 GMT -5
Wire in a new insulated fuse holder and fuse of the proper value. Never bypass fuses. They are there for a reason.
