Post by walleye1963 on Jul 8, 2015 12:19:21 GMT -5
Hi guys I just put a new 19mm carb on.it has a 72cc bbk.I put a #90 mj in it starts right up put when I take off it sputters for sec or too then takes right off.could it need a bigger mj? Got needle in the middle should I move it up? Thanks for the help.
Post by walleye1963 on Jul 8, 2015 14:27:00 GMT -5
Jus tryed a #85 mj same thing.any thoughts or help.
Post by Silar on Jul 8, 2015 16:16:33 GMT -5
Are you going WOT at takeoff?
Post by walleye1963 on Jul 8, 2015 17:50:37 GMT -5
Noit starts doing it as soon as I give it any kind of gas .the last 2 carbs did it.the stock one and the so-called 20mm from 02starrider.the needles in the middle .iv tryed the #85/#90mj any ideas this is a new carb got it yesterday.could it be the pilot jet? It don't have no number on it.
Post by kagetenshi on Jul 9, 2015 8:02:43 GMT -5
My taotao 50 was spitting like that for the longest. Then I found a leaky vacuum line which was causing my petcock to malfunction. I replaced it and all is well now.
Post by Silar on Jul 9, 2015 8:15:17 GMT -5
Seriously.. check the vacuum hose going from the petcock to the intake. Try removing the vacuum line from the intake and cap the barb to see if you can now give it throttle.
If you have a manual petcock already installed, then try putting the diaphragm needle clip to the leanest spot. Also, how many turns out is your idle/air screw?
You also may want to double check your float height and make sure it's set right.
Post by walleye1963 on Jul 9, 2015 10:30:27 GMT -5
Manual fuel shut off a/f 21/2turns out.float is good.moving needle just made it worst.cleaned air filter.I'm stumped? What should I do next? Thanks guys.
Post by Silar on Jul 9, 2015 10:32:10 GMT -5
Manual fuel shut off a/f 21/2turns out.float is good.moving needle just made it worst.cleaned air filter.I'm stumped? What should I do next? Thanks guys. I'm guessing you went lean on the clip. Did you try going rich?
Post by walleye1963 on Jul 9, 2015 10:36:29 GMT -5
Its in the middle.I've only went down 1.could it be the intake?
Post by walleye1963 on Jul 9, 2015 11:46:24 GMT -5
Just checked plug its wet and black ?the needles in the middle which way should I go up or down?
Post by Silar on Jul 9, 2015 11:59:00 GMT -5
You could have other issues. That indicates very rich. I'd start checking your CDI, Ignition, and spark plug to make sure you're getting a good spark. Things I'd check... Airbox - Try taking off the airbox cover and running it to see if you can at least get it to use throttle. Carb - Is it bad? Did you try another one to make sure? Enricher - Could it be bad and not working? stuck open allowing more fuel to go through? CDI - Mine went bad and made my scooter run like pure crap. Ignition coil and wire - Obvious.. Spark Plug - Fouled plug? gap too wide or short?
Post by walleye1963 on Jul 9, 2015 12:07:35 GMT -5
Just looked at polit jet it looks like there was something in it I couldn't see thu it.carb it new got it Monday just put it on yesterday.I'll check the rest of what you told me to look into and get back to you soon.thanks
Post by walleye1963 on Jul 9, 2015 12:57:27 GMT -5
OK so I took the air cleaner cover off and air filter and the bogging stopped now what?
Post by walleye1963 on Jul 9, 2015 13:34:51 GMT -5
I took the snorkel thing with the 4 holes at the end and just taped the thing with the 4 holes back on to the air cover box and put it back together with the air cleaner.and the boggings back.what do I do run it without a air cleaner?
Post by Silar on Jul 9, 2015 13:40:02 GMT -5
Does it seem to run fine? Did you take it for a quick spin to see what it would do?
You mentioned that the carb was new. New does not always mean it's going to work fine. There's a reason why most places have a return policy and warranty of some kind. Quality control on Chinese parts isn't always the best.
If it runs fine with the air cover and filter off, then it's more than likely not your CDI, Ignition, or spark plug. All fingers still point to the carb..
