Post by Silar on Jul 9, 2015 13:41:48 GMT -5
I took the snorkel thing with the 4 holes at the end and just taped the thing with the 4 holes back on to the air cover box and put it back together with the air cleaner.and the boggings back.what do I do run it without a air cleaner? Is your air filter clean? A dirty air filter will cause pretty much the same issues. You should be able to wash it in warm water with dish washing liquid..
Post by walleye1963 on Jul 9, 2015 15:00:21 GMT -5
I took the needle clip and moved it up a notch .took it for a ride bogging was just about gone so I came home took it up to top notch took for a ride were there's a lot of stop and go.bogged once just for a spilt sec .Luther then that seems to run good.by the wy put air filter on back to way it was.letting it cool then going for a longer ride.let you no how it turns out in a few.thanks
Post by walleye1963 on Jul 9, 2015 16:54:50 GMT -5
Seems to be find now I hope .I'll no tomarow got to go to post office.it's 12mile.i cleaned the air filter yesterday.it starts right up I moved the needle up to the last notch.that seemed to do it.I'll let you no .thanks silar for your help.
Post by Silar on Jul 9, 2015 18:35:54 GMT -5
No problem! I know enough of you guys have helped me out to where I feel like I slept at a Holiday Inn Express now.
That's weird though. I thought you had already tried it up at that setting before? You definitely have some kind of air restriction going on somewhere. Hell, change the airbox out to a POD air filter and see what happens.. That's what I did and it runs awesome! Louder, but awesome, and plug is perfect..
Post by walleye1963 on Jul 9, 2015 22:32:10 GMT -5
No. I went down.this is the first time I tryed it up.ya more or less been having this problem sence I put the bbk on.can you put up a link for a filter like yours.don't really care if its load maybe some of these crazy drivers will here me.thanks again.
Post by Silar on Jul 10, 2015 6:47:53 GMT -5
Post by walleye1963 on Jul 10, 2015 9:06:03 GMT -5
Thanks for the link.so that should take care of any bogging? You said listen to the engine for a rich or lean can you explain? Thanks
Post by walleye1963 on Jul 10, 2015 10:28:26 GMT -5
Just got back from the post office.its still bogging.I have no idea what to try next?
Post by walleye1963 on Jul 10, 2015 23:50:45 GMT -5
Got back from post office.scooter stillp bogging.about to beat my head in.so I go get the jet that came with the carb putit in .fu..king thing runs like a gralp ape.? No more re bogging I hit the gas and it takes off like hell.no number on jet .can someone tell me whats going on .I don't get it ?
Post by Silar on Jul 11, 2015 9:07:34 GMT -5
Same kind of thing happened to me. The 18mm carb I bought came with an 85 jet. I put the 100mm BBK in. Thought for sure I'd have to up the jet to a 95 or 100. That's what everyone else was saying I'd have to run.. Put a 95 in. Got bogging. Went down to a 90 and it was perfect. Even with the POD air filter. Thought I'd be lean, but my plug looks picture perfect. Go Figure.. Just keep an eye on your spark plug..
Post by walleye1963 on Jul 11, 2015 9:40:57 GMT -5
When I got back from the post office I got a chair sat next my scoot and wondered what the hell.looked every thing over and over no vac leaks then I thought about the jet so I put the one that came with carb in .dam thing seems to run great now.no number on the jet .went for a long ride last nite din't bogg once.go figer.checked plug nice tan.I'll post again if It starts messing up again thank you.
