Post by spaz12 on Jul 17, 2015 16:43:08 GMT -5
Post by frank50e on Jul 17, 2015 17:07:30 GMT -5
What numbers are stamped in the case?
Post by spaz12 on Jul 17, 2015 17:13:42 GMT -5
Good Question! I didn't think about that. sai??
Post by sai on Jul 17, 2015 17:47:05 GMT -5
Good Question! I didn't think about that. sai?? KF10 *6101001* Is it this one? It's right above the mount of the exhaust PS: is that engine yours?? Or you just got the photo from somewhere?
Post by spaz12 on Jul 17, 2015 17:53:19 GMT -5
I believe so. Sometimes there is also a stamp by on the rear, by where you fill up the transmission.
Post by spaz12 on Jul 17, 2015 17:58:52 GMT -5
Post by sai on Jul 17, 2015 19:40:08 GMT -5
So this means that kit for super 9lc will work just fine then? And that motoscooterguide site is wrong?
Post by spaz12 on Jul 17, 2015 20:13:20 GMT -5
I'm hoping that someone else will chime in here on this because I don't feel comfortable telling you that it will fit.
Post by derbiman on Jul 17, 2015 20:22:01 GMT -5
Looks kind of like a Morini but the Morini oil pump is behind the magneto. Kymco may have their own design???
Post by spaz12 on Jul 17, 2015 20:35:42 GMT -5
Thanks derbiman for the reply. After reading this: scootdawg.proboards.com/thread/56969/ridiculous"found a great manual for the super 9 but there some major differences from the minarelli and clone minarelli the cylinder is slanted up and the oil pump is by the reed block and the starter look like a gy6 Bendix and it on the bottom not top some cool info if anyone wants to read www.scribd.com/doc/18292347/Kymco-Super-9-50-EN " "ya its a derivative, definitely not the same exact thing. Kymco is weird how they change little things but utilize old designs into the new design. I forget if we were able to use the mina exhaust right now, I thought for certain we used a C20 or C21 on it but Ill have to call my neighbor. Definitely same bbk as the mina. Its a lot like how gears from a 80s earlier model engine work on the AF16/AF18 derived zx50 but not primary gears from a af16/18. You can make it work by changing the whole set together but stock they wont work , yet the different style engine gears drop in. Either way the engine isnt the vertical style and it is horizontal and you need to look for parts for this style. " I guess it's Kymco's way of being difficult. But I'll now say that Minarelli parts will fit. Boy, those damn Kymco's are a pain in the butt.
Post by derbiman on Jul 17, 2015 20:46:10 GMT -5
Crazy!!! They want you to buy genuine Kymco parts so they can make a fortune off of the little guy.(Or girl, Sorry Sai)
Post by spaz12 on Jul 17, 2015 20:55:10 GMT -5
Post by derbiman on Jul 17, 2015 20:55:45 GMT -5
Scrappydog has a whole LC kit that may work,radiator and all!!! It is $499 dollars though. Cha-ching
Post by spaz12 on Jul 17, 2015 20:58:08 GMT -5
Look at that sai, you have a couple looking. It's actually a fun challenge trying to figure that thing out
Post by derbiman on Jul 17, 2015 21:06:04 GMT -5
What size is the wrist pin? Probably 11mm knowing the little Taiwanese bas*****.
