Post by derbiman on Jul 31, 2015 11:15:54 GMT -5
Little to no compression
Post by derbiman on Aug 4, 2015 8:55:03 GMT -5
Any progress in getting it started?
Post by TheAmishSasquatch on Aug 4, 2015 10:45:29 GMT -5
Just pull the plug out and check for a good blue spark. If that's ok, check the compression with a $20 kit from Harbor Freight. If both those check I would put just a thimble ful of gasoline into the spark plug hole and try again. If STILL nothing, there may be something wrong with your kit, your timing is way off somehow or the way you installed the BBK. Spark + Compression + Fuel = combustion thats the thing with the 2 strokes there was just the camshaft after you take off the head and what not i dont know how you can tell the timing or the top dead center If you found a camshaft on a 2 stroke there is something very very wrong. Most likely identifying the engine as a 2 stroke
Post by Deleted on Aug 4, 2015 19:56:25 GMT -5
I over looked that, If you're finding a camshaft it's definitely not a 2 banga
tadd
Scoot Newb
Post by tadd on Aug 7, 2017 0:33:59 GMT -5
Hello, sorry for bringing this old thread up.
I was wondering what cylinders fit daelim s five 2003?
will Honda Dio vertical fit?
tadd
Scoot Newb
Post by tadd on Aug 8, 2017 0:34:09 GMT -5
I'm really trying to find it on the forum, but nothing.
I use to tune and fix alot of scooter back in the days but they were usually minarelli, peugeot, suzuki morini and piaggio engines. I bought Daelim s-five fairly cheap with 6k km but have never fixed Honda engines before. Can anyone help me with finding out what cylinders fit or give me a link to some famous brand like Malossi, Polini or TP?
Thx
