larryhobman
Post by larryhobman on Aug 2, 2015 22:12:07 GMT -5
Hi All, I just added an A9 cam to my 72cc set up that I had already running good. My question is what RPM should I be at? Before the A9 I was running between 7900 and 8300 @ 42 to 44 mph on my gps. Now after the A9 I am at 9000 to 9300 @ 46 to 48 mph on GPS. I had also changed the tach so I do not know if my new cheap tach is better or worse than what I started with. If the new tach is right is 9000 too much and should I change sliders. It does run real good the way it is but, I don't want to blow it up. The cam is a improvement with the 72cc kit, just wish I did it before the cvt tuning I did. Looks like time to start over, let em know what you think. Thank you current set up 72cc with a 60cc head cleaned up casting imperfections in the ports and port matched the spacer. stock carb 18mm with #90 main and #31 idle needle it the middle setting 1.5 turns on the af screw pod filter 6 gram koso sliders 1k koso contra timing mod with stock cdi and coil gates 669 belt
Post by Availien on Aug 2, 2015 22:26:54 GMT -5
