Post by renagade281 on Aug 20, 2015 22:11:21 GMT -5
So this guy has a TaoTao with 20 miles on the odometer. It needs all the vacuum lines and gas lines hooked up. A new cdi a new battery, a new belt. And prolly valves adjusted. He wants 50$. Should I get it? There's obviously no way to hear it run before I buy it
Post by spaz12 on Aug 20, 2015 22:14:14 GMT -5
Even if it needs a new top end, it's probably worth it as an investment. Buy it, fix it and sell it. I would.
Bring a compression tester with you if you can't afford to buy a top end.
Post by Deleted on Aug 20, 2015 22:20:00 GMT -5
Why the heck not? It can be made to run, and run well. If fixing exceeds value for doing so....there is more than $50 worth of good parts there for sure. Part it out, it might take some time but, just selling the wheels and tires will get you way more than you invested I would think.
I'll bet you can fix it and flip it cheap though.
Good luck.
Bill
Post by frank50e on Aug 21, 2015 4:18:57 GMT -5
Title?
Post by aeroxbud on Aug 21, 2015 4:35:31 GMT -5
Sounds like a good deal
Post by scooterpimp on Aug 21, 2015 5:50:06 GMT -5
Cant go wrong for 50 bones.
Post by renagade281 on Aug 21, 2015 9:20:48 GMT -5
If it has a title then I'm going to get it. No title, no deal
Post by frank50e on Aug 21, 2015 10:56:31 GMT -5
Hell yeah.With only 2 miles he may just have the MSO check with the DMV in your state how that works.
Post by Fox on Aug 21, 2015 11:22:30 GMT -5
Who cares about the title? Even if you can't flip it or register it it's still worth $50 just for the belt/pulleys. The rest is gravy. Spare engine, tires, relay, starter, etc... Strip it down to the bare frame, keep all the parts and the screws and bolts throw the frame to the scrappers. Hell, if you were to buy just the nuts, bolts and screws it would cost you. Those things are invaluable to have laying around in the garage. Unless you don't have a garage.
Post by renagade281 on Aug 21, 2015 12:25:21 GMT -5
lol i dont have a garage but you are right... im gonna buy it
Post by Deleted on Aug 21, 2015 19:42:24 GMT -5
Title? We don't need no stinkin' title. I never got one with mine but, 50cc's are not registered in my state so it makes no difference. It is NOT stolen as I got it from my friend but, it is an older model and a lot of scoots did not come with titles back then I have read. At least around here in KY.
Bill
