Post by efeseu on Aug 28, 2015 11:04:59 GMT -5
Hi, I don't know what the hell is going on with this thing.. I started it up today and saw that something was leaking from the carb - had a smell and realised that it was petrol leaking from there. It only happens when the engine is running - when I turn it off it drips for like 10 seconds but then stops. Here's a video: sendvid.com/ypn7faivPlease help! The carb was cleaned 5 days ago...
Post by derbiman on Aug 28, 2015 11:08:48 GMT -5
The petcock is probably vacuum operated. It will only leak with the engine running as long as it has vacuum. Check your hoses and clamps.
Post by derbiman on Aug 28, 2015 11:13:02 GMT -5
If everything is ok with the hoses and it still leaks while running, the float may be stuck in the carb allowing fuel to run out of the overflow. Usually to unstick the float,tap the bowl lightly with a screwdriver handle. Lightly!!!
Post by efeseu on Aug 28, 2015 11:14:21 GMT -5
The petcock is probably vacuum operated. It will only leak with the engine running as long as it has vacuum. Check your hoses and clamps. Do you mean this?
Post by derbiman on Aug 28, 2015 11:17:16 GMT -5
Yes, the bottom connection is for vacuum which opens the valve. The top connection is for the gas line.
Post by katastroff on Aug 28, 2015 11:17:51 GMT -5
Tight up that bowl drain screw.
Post by efeseu on Aug 28, 2015 11:18:36 GMT -5
Post by katastroff on Aug 28, 2015 11:21:00 GMT -5
Clip a small hose to it, fold the open end in 2 and ziptie it real tight.
Post by efeseu on Aug 28, 2015 12:27:45 GMT -5
If everything is ok with the hoses and it still leaks while running, the float may be stuck in the carb allowing fuel to run out of the overflow. Usually to unstick the float,tap the bowl lightly with a screwdriver handle. Lightly!!! Hit it a few times here and there and still :< When I turn the engine on, it doesn't leak for about 10-15 seconds but then starts to leak - hmm..
Post by katastroff on Aug 28, 2015 15:52:09 GMT -5
Did you block that drain?
Post by efeseu on Sept 1, 2015 17:30:35 GMT -5
I have no idea what the hell this was. It was still leaking and I took it for a ride for like 2 mins and it stopped and doesn't leak anymore! LOL
Post by derbiman on Sept 1, 2015 19:46:44 GMT -5
Float valve was probably stuck and the ride broke it loose.
Post by efeseu on Sept 4, 2015 8:37:57 GMT -5
Float valve was probably stuck and the ride broke it loose. That's what I think too
