Post by Silar on Sept 1, 2015 14:03:43 GMT -5
My wife has a Yamaha Vino XC50 (2007 4T model) that runs great, it's just hard starting cold... have to give it a little gas at first until it warms up. I'm sure it's the enricher on the carb, but was wondering if anyone knew were I could get a replacement enricher, or even new carb from?
I don't plan on working on it until late fall/early winter so that we can ride our scooters until it gets cold. At that point I'll do quite a bit more, as I want to check the valves, etc..
In other words, right now I'm not in any rush to change it out, but as I'm looking online, I can't seem to find a source anywhere that actually carries either the enricher itself, or a complete carb setup for this scoot..
Just curious as I've not come up with anything other than the 2T racing carbs...
Thanks guys!
Post by moofus02 on Sept 1, 2015 16:49:09 GMT -5
I would pull it off and make sure it is working and clean the carb. Probably all that is wrong with it
Post by Silar on Sept 17, 2015 16:46:30 GMT -5
I would pull it off and make sure it is working and clean the carb. Probably all that is wrong with it Carb is fine. It's the enricher that's the problem. I plan on that coming up this winter, but wanted to go ahead and get another carb on order, or at least a replacement enricher...
