Post by renagade281 on Sept 11, 2015 18:09:26 GMT -5
Post by renagade281 on Sept 11, 2015 18:21:55 GMT -5
Post by spaz12 on Sept 11, 2015 18:27:00 GMT -5
Pull the variator, see if that does anything. Pull the fan cover too to see if it's coming from that side
Post by spaz12 on Sept 11, 2015 18:31:32 GMT -5
Hopefully it's not the bottom end
Post by renagade281 on Sept 11, 2015 18:35:17 GMT -5
Never mind I'm an idiot. The kickstand was rubbing against it. Lol I almost wanted to deleted this thread but I will let y'all clown on me
Post by spaz12 on Sept 11, 2015 18:38:04 GMT -5
Post by katastroff on Sept 11, 2015 19:39:05 GMT -5
We all do stupid idiotic stuff so i'm not gonna go clown on you. Beside, i think you're handy enough with tools to use a hammer.
Post by renagade281 on Sept 11, 2015 19:56:21 GMT -5
Lol so I just need to buy a variator, belt and ignition and I'm good to go. She runs perfect
Post by spaz12 on Sept 11, 2015 20:01:06 GMT -5
I actually had a lot of fun with one of those. But they eat pipes like they're going out of style. You should definitely find a lighter pipe.
Post by renagade281 on Sept 12, 2015 9:44:04 GMT -5
should a rear pulley spin without wabble if there is no belt on it? it seems like its out of balance or not perfectly round but maybe its just because there is no belt on it? i dont know
Post by iwiketuddlz on Sept 12, 2015 18:21:37 GMT -5
It deff shouldn't wobble or anything that thing turns at some high rpm it would vibrate really bad if so..
Post by Fox on Sept 12, 2015 18:32:55 GMT -5
There might be a chunk of the old belt stuck in between there making it look bent.
Post by frank50e on Sept 12, 2015 19:09:16 GMT -5
What's spinning the rear pulley with no belt?
Post by Fox on Sept 12, 2015 19:14:48 GMT -5
What's spinning the rear pulley with no belt? Once you pull off the bell you can grab the clutch pads and spin it quite fast with your hand.
