Post by renagade281 on Sept 16, 2015 14:25:05 GMT -5
when i try to electric start nothing happens when i push the button but if i jump the starter selenoid it fires right up... does this sound like the actual button for the electric start has gone bad?
Post by spaz12 on Sept 16, 2015 14:37:47 GMT -5
Are the brake lights working? Could also be those switches too. Also, some scooters have that stupid switch in the kickstand. The solenoid itself could also be an issue.
Post by Fox on Sept 16, 2015 14:41:22 GMT -5
Could be the fuse by the battery is blown
Could be a bad starter relay as stated above
Could be the battery is low
Could be an issue with a brake light switch on the handlebars. Lot of people don't know that squeezing either brake lever will allow you to start the scooter.
