Post by frank50e on Sept 19, 2015 10:50:35 GMT -5
Yeah I grew up on the streets of Chicago so "ghettos" don't bother me but Deliverence left an imprint on me
Post by Deleted on Sept 19, 2015 10:52:21 GMT -5
Yeah I grew up on the streets of Chicago so "ghettos" don't bother me but Deliverence left an imprint on me It left an imprint on Ned Beatty too, ha ha. Bill
Post by iwiketuddlz on Sept 19, 2015 13:47:56 GMT -5
That sux!!! I have broken a tatol of 5....<<< yea 5!crazy right, damn compression and junk l..... Chinese metals Only way to fix is buy a new one IMO
Post by renagade281 on Sept 19, 2015 14:04:38 GMT -5
Post by tiny on Sept 19, 2015 14:15:30 GMT -5
NIce Job Mate
Post by iwiketuddlz on Sept 19, 2015 15:07:09 GMT -5
Ha sweet!! Very sneaky sir
Post by Fox on Sept 19, 2015 16:07:26 GMT -5
If you drill a hole where the variator nut is you can start the engine with a drill and a socket. Saves the battery and the starter.
Post by renagade281 on Sept 19, 2015 16:28:09 GMT -5
whoa i did not know that.. good call
Post by Fox on Sept 19, 2015 16:29:24 GMT -5
This is a good topic to let everyone know that you can avoid this ever happening by moving the kick lever on the shaft counter clockwise so it's pointing up at around 1:30 to 2:00 position. This angle means that each kick will have more travel. What breaks the case is when the kick lever gets to the bottom (6:00) and you are standing on it acts like the lever it is and you get a lateral movement. I could explain it better but I would need paper and a marker and an easel. Just know that moving the lever up like this helps you avoid breakage and makes starting the scooter easier. One mistake people make is they kick the kicker a bunch of times in a row really fast wham wham wham wham! That can break things. You have to work the kicker slowly until you feel resistance which means the engine is on a a compression stroke. Then you let the kick lever come back up to the top and then push firmly. Your foot should never come off the lever.
Post by Deleted on Sept 19, 2015 16:46:02 GMT -5
This is a good topic to let everyone know that you can avoid this ever happening by moving the kick lever on the shaft counter clockwise so it's pointing up at around 1:30 to 2:00 position. This angle means that each kick will have more travel. What breaks the case is when the kick lever gets to the bottom (6:00) and you are standing on it acts like the lever it is and you get a lateral movement. I could explain it better but I would need paper and a marker and an easel. Just know that moving the lever up like this helps you avoid breakage and makes starting the scooter easier. One mistake people make is they kick the kicker a bunch of times in a row really fast wham wham wham wham! That can break things. You have to work the kicker slowly until you feel resistance which means the engine is on a a compression stroke. Then you let the kick lever come back up to the top and then push firmly. Your foot should never come off the lever. That is exactly correct and the first thing I did on my scoot when I got it. My friend that had the scoot said he never used the kicker as it didn't work. Well, i tried it and...yes...it was positioned at about 4:00 and you only got maybe 1/2 cycle by kicking it. I pulled it off and re positioned it to about 1:00 so, when I kick it, it spins that motor enough that it usually starts with a single kick. I actually use my right leg standing beside the scoot as you really need to push backward at first, and not down when it is in this position. This was a very good post and folks should be aware that you can move the kicker easily so it works very well without stress on the case, even though those cases are made from crap metal, as we all know. Bill
Post by spaz12 on Sept 19, 2015 16:46:19 GMT -5
I see the Typhoon in the background. I used to have one, and man was it fun!
Post by renagade281 on Sept 19, 2015 18:00:13 GMT -5
I see the Typhoon in the background. I used to have one, and man was it fun! Yes they are very fun.
Post by frank50e on Sept 19, 2015 19:14:23 GMT -5
How is the socket connected to the drill?Just a deepwell in the chuck?
Post by Fox on Sept 19, 2015 20:07:38 GMT -5
Post by frank50e on Sept 19, 2015 20:37:29 GMT -5
Thanks man those look handy for various things
