Post by iwiketuddlz on Nov 1, 2015 14:46:09 GMT -5
You need to do a air leak down test <<< this is absolutely essential on any 2stroke engine!!! Also compression check is a must sir!!!!!!
Post by niz76 on Nov 1, 2015 15:08:02 GMT -5
It could be cranking really fast due to low compression. 1st thing you should check is compression. Everything else will be futile if there's not enough compression. (Minimum of 90-100psi to start. 130 would be really good. 150-160 would be great!)
