Post by renagade281 on Sept 22, 2015 19:08:36 GMT -5
What is the purpose and can I get rid of it
Post by katastroff on Sept 22, 2015 19:19:45 GMT -5
I would very much keep that since kickstarting your scooter aint really an option.
Its for the electric starter.
Post by paulmohr on Sept 22, 2015 20:39:48 GMT -5
Its the bendix gear for the starter. It should engage with a larger gear that is on the variator.
If you don't have a kick starter that is a pretty important item.
Post by Fox on Sept 22, 2015 21:04:16 GMT -5
Don't start the engine unless you have the cover on to hold the bendix in place to avoid damaging the bendix or the engine case.
Edit: If you want to run the engine without the belt cover you can remove the bendix and do the drill and socket start trick. You can wiggle it out of there without removing the drive face.
Post by renagade281 on Sept 23, 2015 8:08:00 GMT -5
Oh ok
