Post by 180°off on Sept 23, 2015 13:10:27 GMT -5
My fried just picked up a 150moped. Its not charging the battery and the headlights are not coming on. all other lights work. Im going to test the stator here in a lil bit. The real question i have is there is a 3 prong male connector with 2 wires a black with white stripe and a green. I cant find where they go to.There is no female connector anywhere. the male connector is right by the battery box. I know that green is ground and that the black is probably positive. Any help?
Post by 90GTVert on Sept 23, 2015 13:28:01 GMT -5
Sounds like the wire combo used for a coil or kill switch. It's not uncommon to have an unused connector. Sometimes Chinese scooters even have wires with no ends or precautions to insulate them.
Post by 180°off on Sept 23, 2015 13:52:59 GMT -5
can u send me a link of how to check the voltage rectifier/regulator?
Post by 90GTVert on Sept 23, 2015 14:37:59 GMT -5
Post by gene563 on Oct 14, 2015 13:38:02 GMT -5
Dracula, Did you ever sort out this problem? It sounds like the same issue I was having. All indications pointed to the R/R, but it ended up being crossed wires at the R/R plug. I moved them around and got charging V and lights working.
