Post by Fox on Oct 7, 2015 20:06:19 GMT -5
If there was no gasket there should have been at least some RTV silicone applied there or some ultra gray and when you install the intake with the sealant let it dry for 12-24 hours before you run the engine. On my rebuild I put sealant between the reed block and the engine and between the reed block and the intake boot. I would have to say that a zip tie is not gonna cut it. You'll need to get a good quality hose clamp. Take the intake to the auto parts store and have see if you can find a narrow one that fits between the two ridges on the intake boot. The fan screws are lost? That sux cause they are just the right length so they hold the fan onto the flyweel but fall short of hitting the stator.
Post by Deleted on Oct 7, 2015 20:51:04 GMT -5
I doubt that is solid enough as you can't generate the required clamping force with a zip tie. Just get the right sized hose clamp...I see a lot of folks using them instead of the stock 2-piece clamps that come with our scoots. To me, decent hose clamp would seal all around and be even better. Other fellows that know more can tell you if this is right or not.
Bill
Sorry, yet another post where I did not see the page jump, and I now see Fox has said the same thing before me. I really need to pay more attention to that, ha ha.
Post by spaz12 on Oct 7, 2015 20:57:16 GMT -5
I don't think a zip tie is enough to clamp that around your carb. Now you'll have an air leak. This is a 2 stroke Vino, correct? You want all the air entering the motor metered by only the carburetor. An air leak is un-metered air. No bueno EDIT: I did the same thing Bill lol
Post by Jordan D on Oct 7, 2015 21:20:49 GMT -5
This is great information I had no idea I thought the zip tie was doing alright. Ill see if I can get a gasket for the intake if not some silicon or similar sealer. Lost the screws for the fan is fine. I have one but most of the screws basically suck and strip out if you try to take them off so I am replacing them all eventually with better quality. As I go through the project I am getting replacement hardware as needed.
Post by Jordan D on Oct 7, 2015 21:21:25 GMT -5
And yes its a 2 stroke
Post by spaz12 on Oct 10, 2015 2:14:48 GMT -5
if its a lean jet issue a 105 wont solve it, its a pilot jet issue. unless you have a low fuel bowl level to cause it to race away or a air leak. having no filter only makes it worse. try rich'n up the idle air screw and teke her for a spin. all carb adjustments should only be done to a warm engine He's right about the low fuel level causing it to go lean and the motor to race. Learned this as a kid when we'd run our carbs dry at the end of the day so that we could put the bikes away for the week.
Post by Jordan D on Oct 11, 2015 19:13:18 GMT -5
So what about this...I have a 90 jet and 87.5 jet. Would it be worth a try to put the snorkel back in and trying a smaller jet so I'm dealing with less air and fuel?
Post by spaz12 on Oct 11, 2015 19:16:18 GMT -5
So what about this...I have a 90 jet and 87.5 jet. Would it be worth a try to put the snorkel back in and trying a smaller jet so I'm dealing with less air and fuel? Have you confirmed that you don't have a problem with a low fuel level?
Post by Jordan D on Oct 11, 2015 19:17:58 GMT -5
How would I check for low fuel level?
Post by katastroff on Oct 11, 2015 19:19:57 GMT -5
Look into the gas tank.
Post by spaz12 on Oct 11, 2015 19:20:33 GMT -5
You gotta check the float level.
I gotta run, hopefully someone will clue you in while I'm away.
Post by Jordan D on Oct 11, 2015 19:28:47 GMT -5
Well I run it with gas in the tank obviously...as for the float in the bowl how do you check that? The vino carb doesnt have an adjustable float. The float needle is connected with a plastic bracket so there isnt a metal connector like in some other ones ive seen on youtube that you can tweak. But I did get some hose clamps and replaced the gaskets on the intake for prevent air leaks. Im still waiting on the cooling fan to come in so I can start it up again.
Post by katastroff on Oct 11, 2015 19:43:49 GMT -5
If the float is stuck, usually a few hits with the big end of a screw driver will set it free.
Post by Jordan D on Oct 11, 2015 20:14:36 GMT -5
so if the scooter starts taking off while its on the kickstand and I tap the bowl and it stops then the bowl is getting stuck?
Post by katastroff on Oct 11, 2015 20:24:46 GMT -5
Not quite, if the float is stuck, fuel cant enter the bowl. No fuel in the bowl, you start running lean, idle goes up and when the bowl goes empty it eventually dies.
