Post by sobotek on Oct 1, 2015 12:28:47 GMT -5
Hey guys.. Just installed my s6 streetrace today.. And i forgot to tighten the spark plug when i went for a ride.. I wot for 1mile at 8800rpm and then when i lett it off.. Something banged and the scoot died.. Had to wait for 5min and then it would start right up.. I did WOT again and the same thing happened.. I couldnt believe i did a soft seasure 2 times.. But i was not shure the first time what it was.. I went home at 6000rpm or 20mph.. I wanted to check my spark plug.. And it was not tight i could screew it in for about 4 turns..
Could this be the problem to soft seasures?
Because i used to ran this cyl with a 90MJ and i doo it now also.. Thats why i couldnt beleive i was to lean..
Post by Fox on Oct 1, 2015 12:57:05 GMT -5
If you tighten the plug and it stops seizing then you will have answered your own question.
Post by sobotek on Oct 1, 2015 13:19:17 GMT -5
Hehe.. I know that.. Butt it was getting dark and i didnt want to ride anymore.. So i thought that you more expirienced guys can chime in..
Post by ams417 on Oct 1, 2015 13:23:12 GMT -5
Put a new plug in and make some runs. Check the color against a plug chart to see where you are lean versus rich.
Post by filip on Oct 1, 2015 16:52:30 GMT -5
Brand new streetrace? WOT? I am all for hard breaking in, but unfortunately the streetrace is known for soft seizing a lot when new, be more gentle with it please
Post by sobotek on Oct 2, 2015 14:18:21 GMT -5
Filipe nije nov streetrace kit..
Streetrace kit isnt new.. It has around 2500miles on it.. The good thing is its running fine now when i tightened the plug.. So remember to tighten those plugs..
Post by filip on Oct 2, 2015 17:58:36 GMT -5
Great, it probably sucked more air through the thread Super druže
Post by ams417 on Oct 2, 2015 19:43:18 GMT -5
Glad it's solved. Riding is much better than troubleshooting.
Post by sobotek on Oct 4, 2015 2:15:06 GMT -5
Glad it's solved. Riding is much better than troubleshooting. I hear that..
Post by PIG on Oct 4, 2015 2:40:53 GMT -5
If it was me I'd be pulling the top end off and having a look see. Once the plastics are off its only 4 bolts and 2 exhaust bolts to put your mind at ease. I personally wouldn't trust a top end that I've soft seized twice with out having a look at it.
Post by Clank on Oct 4, 2015 3:45:15 GMT -5
Ok, I'm a 4T guy. What exactly is a "soft seize"?
Post by Corrosion on Oct 4, 2015 5:56:35 GMT -5
Piston expands faster than the Cylinder. The piston will stop due to friction cool and release. it generally leaves contact marks on the piston skirt.
Post by Clank on Oct 4, 2015 21:24:16 GMT -5
Is this 2T only thing or do they call it something else for 4T's that I am not aware of?
Post by sobotek on Oct 6, 2015 8:12:41 GMT -5
I did take the whole engine feom the frame and i am about to rebuild the whole engine.. Everything new.. From crankshaft to every bolt..
Does anyone have any experience with naraku 50cc cylinder kit? It is supposed to have a little more power than the original top end.. Thanks for the info
