Post by PIG on Oct 10, 2015 18:04:13 GMT -5
Post by 190mech on Oct 10, 2015 18:42:27 GMT -5
Post by PIG on Oct 10, 2015 19:35:16 GMT -5
Thanks. Do you know if the pumps come with the three grommets that the hoca stud kit come with? I'll end up painting the pump and cover white and black so I'll probably just stick with top performance pump.
Post by spaz12 on Oct 10, 2015 19:44:00 GMT -5
I've heard that they are nothing but problems PIG, that they leak and that they break. Especially on the high performance motors. aeroxbud, Lucass2T what are your thoughts? You guys know much more about them.
Post by jmkjr72 on Oct 10, 2015 21:07:04 GMT -5
I needed to mod the pumk to get it b to fit the Zuma case you need lon get studs then what there is out there You will only be able to use 2 of the three bolts to mount it b to the case and have to make a part to cover the stator
Post by PIG on Oct 10, 2015 21:42:58 GMT -5
I needed to mod the pumk to get it b to fit the Zuma case you need lon get studs then what there is out there You will only be able to use 2 of the three bolts to mount it b to the case and have to make a part to cover the stator[/quote Do you have any pics of your set up?
Post by Lucass2T on Oct 11, 2015 1:38:28 GMT -5
I've heard that they are nothing but problems PIG, that they leak and that they break. Especially on the high performance motors. aeroxbud, Lucass2T what are your thoughts? You guys know much more about them. I've never heard about leaking problems with mechanical driven waterpumps on minarellis. But then again i've never owned a watercooled kit, and a lot of the fast ones i see use an electric pump. I think that's because you don't have to sacrifice engine power to drive the pump. I dunno...i sure would dare to to use the stock pump. Maybe put a stage 6 snail on? The stock parts may have too big of a output for 11-12K+ rpms. That would give a big resistance and maybe overpressurize parts like the radiator, hoses and pump itself? Maybe thats why they leak? I know it can give problems on car engines...pushing the freeze plugs out and all.
Post by PIG on Oct 11, 2015 3:20:14 GMT -5
Dam I never knew it would be such an issue to water cooling this thing. So these mechanical pumps don't work on Zuma cases? Surly someone has done this conversion and knows what I need.
Post by Lucass2T on Oct 11, 2015 3:39:57 GMT -5
Oh but every minarelli case can be plug and play converted to watercooling. Really easy you just need the parts but it's all bolt on.
You need that waterpumpcover where normally the airscoop sits. You need the 3 extension bolts with those rubber rings. Well thats actually it.
Post by PIG on Oct 11, 2015 4:10:44 GMT -5
That's what I thought, but from what I'm hearing the North American version of the Yamaha minarelli is different.
Post by iwiketuddlz on Oct 11, 2015 4:50:51 GMT -5
yea They do leak!! I have tried about every trick in the book to get it to stop and nada!!! Ugh I even tried a double lip seal and it just got hot and burned the seal up!! But it isn't very much I mean it leaks very minuscule ....
Also I believe I have a complete stae6 water pump laying around. Somewhere....
Post by Lucass2T on Oct 11, 2015 8:10:09 GMT -5
That's what I thought, but from what I'm hearing the North American version of the Yamaha minarelli is different. Hmm...that would be kinda strange...but its possible. You want me to take pic from my aircooled shortcase and the aerox longcase i have laying around?
Post by PIG on Oct 11, 2015 14:48:27 GMT -5
Post by jmkjr72 on Oct 11, 2015 20:14:15 GMT -5
Post by Lucass2T on Oct 12, 2015 8:04:32 GMT -5
Don't have specific information about both of em. But they are both top of the line high end products. Both in the same rpm and hp range. I think metrakit uses the pro race cylinder as a basis for the little dirtbikes and the metrakit mini GP cup. I think the metrakit pro race was initially developed for the minarelli AM6 engines and later adopted for scooters. The metrakit has a triple port design...not better or worse than a bridged one since the triple design is also used in the 50hp TM racing KZ kart engines. I think the Evo has a bit more transferport area. Dunno how much you care about that? Or how important it is when thinking about porting it? I think for an enthousiast it doesn't really matter which one you buy. Maybe is does more for a scooter racing team where sponsors and shareholders have benefit from a winning machine.
