Post by 190mech on Nov 25, 2015 4:49:43 GMT -5
Looking at the transfer tunnels,one side has a 'dip' to clear the oil pump..Thats what the 90cc stuff has,its likely a 50-52mm cylinder.It would require a bunch or machine work to make it fit..
Post by 90GTVert on Nov 25, 2015 6:37:22 GMT -5
It's marked 82cm3(cc) on the side too and has relatively thick cylinder walls, so it should be a 90cc style cylinder as 190mech said and won't fit without case clearance. Even if it did, the timing and other specs may be off with a stock stroke crank since that's likely meant for more like 42mm stroke (stock is 39.2).
