Post by 180°off on Jan 11, 2016 16:52:22 GMT -5
At the junk yard today and saw either a 50 cc or a 150 short block with rear disc break. Do they come from factory like that or did someone buy a hub kit? I am going back to get it tomorrow, just wanted to know?
Post by Clank on Jan 12, 2016 5:56:10 GMT -5
It's probably a 150. I haven't seen a factory 50 with rear disc, unless maybe one of the European makers is doing it. Dbl check that the axle sz and splines are the same.
Post by Dj Chocolate on Jan 12, 2016 21:42:47 GMT -5
Post by Dj Chocolate on Jan 12, 2016 21:43:24 GMT -5
Post by Dj Chocolate on Jan 12, 2016 21:44:15 GMT -5
if it it's a yamaha aerox for real.. it's like gold if u like 2t tuning
Post by niz76 on Jan 12, 2016 21:58:26 GMT -5
There's a few 50's that have rear disk- some malaguti's and I've even seen Roketa's with rear disc (they rent them in Clearwater). Couple folks here with rear disc TGB/Morini's also...
Post by niz76 on Jan 12, 2016 22:03:42 GMT -5
You can see the dual master cylinders on this Roketa 4 poke... I've also seen Roketa 2t's with front/rear disk brake...
Post by 180°off on Jan 17, 2016 16:36:03 GMT -5
Its definitely a qmb engine. I saw the stampings the other day when I went back, but could not get the disc off. I will have to go back again to buy the whole thing casing and all. 10 bucks and comes with stator and clutch. No to shabby.
Post by Clank on Jan 17, 2016 22:00:38 GMT -5
If you look close there's only one master cylinder on that scoot niz76. One protrudes through the plastic the other is a plastic cap similar to the TaoTao VIP.
Post by TurboTyler on Feb 23, 2016 0:17:53 GMT -5
The main problem with converting to disc brakes is a whole new wheel plus, there isn't a factory mounting location on the frame for the caliper.
Post by gsx600racer on Feb 26, 2016 1:11:21 GMT -5
Beta Eikons, Kymco Super 9's, Roketa MC-01-50Y to name a few that are 50cc with rear disc. Here is a trick, go to racingplanet.com. Search for "rear disc brake" Select a brake rotor or caliper. Select "Application Tab" You will see a list of make and models that have a rear disc.
Post by greggkinney on Jul 16, 2017 0:41:53 GMT -5
At the junk yard today and saw either a 50 cc or a 150 short block with rear disc break. Do they come from factory like that or did someone buy a hub kit? I am going back to get it tomorrow, just wanted to know? i know this threads been dead for over a year but a bn139qmb (znen/bintelli) with a factory rear disk
Post by 180°off on Jul 16, 2017 14:47:32 GMT -5
Could have been it. It had a aprilia sr50 rim on the qmb engine. Wish I was able to see the whole thing before disassembled and crushed
Post by Deleted on Aug 18, 2017 13:36:34 GMT -5
