Post by 180°off on Jan 28, 2016 14:37:40 GMT -5
Ok! I got my scoot running good, at least I thought. It starts in like one to 2 kicks, it seems to idle great! But now when I accelerate it does not want to go fast. I'm probably going like 5mph. I lowered the clip one notch on the needle so it wouldent bog, I checked the rollers and they looked ok, small flat spots but I don't think big enough to effect that much. Any other iders? Maybe I have to put the clip back because before I didn't have air filter on it?
Post by niz76 on Jan 28, 2016 15:50:33 GMT -5
Going from no air filter to installing one is a pretty big deal carb-wise. You'll probably have to re-tune the whole carb and not just the needle! Adding a filter will richen the mix so try downjetting... hope this helps!
Post by Sitticuss on Jan 29, 2016 0:29:41 GMT -5
Pull off the filter and see if it makes a big difference...
