Post by pete130 on Aug 27, 2019 22:21:08 GMT -5
Well my secondary gear up kit arrived today went from 43/13 to 40/15 3.3 to 2.6 should help with top end also 10 new jets 125-170 now waiting on new piston kit and I can ride again well getting around on stock red devil 50cc gets me from a to b lol
Post by aeroxbud on Aug 28, 2019 5:31:10 GMT -5
Well my secondary gear up kit arrived today went from 43/13 to 40/15 3.3 to 2.6 should help with top end also 10 new jets 125-170 now waiting on new piston kit and I can ride again well getting around on stock red devil 50cc gets me from a to b lol Nice. Should have the gears fitted by the time the piston turns up.
kylem
Scoot Newb
Post by kylem on Aug 29, 2019 2:22:06 GMT -5
Hello all,New to scooters and this forum. Friend just gave me a 50cc Taotao and have been doing some work to get it running good.. Everything works like a champ now and just ordered/recieved today the battery cover panel. Thing is it didnt come with screws. Anyone happen to know what size screw it takes? Im assuming it's metric. If anyone knows or has calipers to measure it would be much appreciated.By the way this is the cover I got...
Battery Box Cover for 50cc Scooter Jonway Taotao Sunny SunL Roketa Tank by VMC CHINESE PARTS
Post by aeroxbud on Aug 29, 2019 3:16:57 GMT -5
Welcome to the forum kylem
Post by Raizer on Aug 30, 2019 9:45:17 GMT -5
Been buying a lot of small genuine Suzuki parts and replaced all the rounded out JIS screws in my A50's engine. Slightly more exciting than that though is the 45mm piston kit from Sweden Going to get the factory 41mm cylinder bored out by NZ Cylinders before I port it, can see a lot of areas that would benefit from a tickle with a burr. And tonight I took advantage of the 18% off code from Treatland and ordered a chamber exhaust Also a new 32mm OD header from Yamaha, turns out the old Yamaha FS1 header will fit right onto the Suzuki once the flange has 2mm ground off, meant to be a good upgrade.
Post by ryan_ott on Sept 1, 2019 9:04:58 GMT -5
The time has come to replace my wore out HiT clutch. After thousands of miles and a few builds it has served me well and I can see using anything else. Tried a Polini and it didn’t compare.
Post by 90GTVert on Sept 2, 2019 6:34:59 GMT -5
Hello all,New to scooters and this forum. Friend just gave me a 50cc Taotao and have been doing some work to get it running good.. Everything works like a champ now and just ordered/recieved today the battery cover panel. Thing is it didnt come with screws. Anyone happen to know what size screw it takes? Im assuming it's metric. If anyone knows or has calipers to measure it would be much appreciated. [/a] [/quote] I believe it's #8 that works well for many tasks on most Chinese scoots. You can get a screw assortment with clips as well at Harbor Freight for about $5 that has screws that usually cover whatever comes up.
Post by pete130 on Sept 6, 2019 3:47:10 GMT -5
Well I had to bite the bullet and buy this just to get a piston dam expensive piston but custom made so you get what u pay for but this kit is a good deal It's a bridged 9 port full alloy lighted piston barbell 4mm extra long to change port timing to what u want any way will be glad to get my motor didnt lean out have a very hi compression and head had moved off center and piston just clipped head till it went boom lol hard lesson to learn will be making up alloy dowels to keep head in center I dont run a barrel or head gasket lol
Post by dexameth on Sept 6, 2019 15:47:51 GMT -5
2K launch springs, connector kit for my stator-to-wire harness, and a new engine mount... no more weeble wobble! The bushings in the mount are so gone that you can literally wiggle the entire engine with your hand on the back wheel.
Post by ryan_ott on Sept 6, 2019 17:30:16 GMT -5
New clutch is here, yay! Slightly different design of what I had, springs are easier to get on which is a bonus. I’ll swap it out later tonight.
mattyslimz
Post by mattyslimz on Sept 6, 2019 18:23:31 GMT -5
A new OEM stator for Zuma. I believe I damaged the original while changing an oil seal. Naraku solid-spline non washer pulley doohickey for my RX8. Some spark plugs. And you can never have too many exhaust gaskets.
Post by pete130 on Sept 6, 2019 22:50:05 GMT -5
Finally bought a new fan my last one fell off while riding made a mess lol Not bad for $25
Post by aeroxbud on Sept 7, 2019 15:50:41 GMT -5
Finally bought a new fan my last one fell off while riding made a mess lol Not bad for $25 They are supposed to flow more air. Could be a good buy then.
Post by Raizer on Sept 7, 2019 19:25:01 GMT -5
And another haul of small genuine Suzuki parts lol
Post by FrankenMech on Sept 7, 2019 20:59:07 GMT -5
And another haul of small genuine Suzuki parts lol A decent headlight
