Post by 180°off on Feb 28, 2016 11:58:40 GMT -5
So I was taking apart this Yamaha engine that I got from work and guess what I find? A malossi 70cc bbk! Yeah yeah!!! What about those cooling fins that broke off? Is that ok or should I get a new head?
Post by frank50e on Feb 28, 2016 12:51:52 GMT -5
The first step I would do is mic the cylinder and piston.If they are within tolerance I'd do a hand home and reassemble.Might be a good time to invest in a CHT gauge and gently see if the missing fins cause overheating.Personally I would take an old head,cut and shape new ones and weld them in.But I have the skills and equipment to do that.Having someone else do it for a fee would be cost prohibitive.Actually I would probably use my existing head cause I don't have the time to tackle that job.
Post by frank50e on Feb 28, 2016 12:53:56 GMT -5
From the pic looks like something has been into the combustion chamber.
Post by aeroxbud on Feb 28, 2016 14:28:06 GMT -5
Always hard to tell how smooth a bore is in a picture. If you can use it will be a free upgrade
Post by moofus02 on Feb 28, 2016 15:27:04 GMT -5
You can get a 47mm head for like 15 bucks
Post by spaz12 on Feb 28, 2016 15:30:54 GMT -5
I have an MHR Rep head if you want it. Has the O ring with it.
Post by frank50e on Feb 28, 2016 17:02:32 GMT -5
Much better suggestions than mine,
Post by 180°off on Feb 29, 2016 2:12:43 GMT -5
